Old 08-02-2013, 08:34 PM   #1
Avalance1
Replace my wheel cylinders
How do I remove them
Avalance1 is offline   Reply With Quote
Old 08-02-2013, 09:04 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Replace my wheel cylinders
You need to remove the wheels,brake drums and then you can get to them.There are springs and retainers inside the drums.Keep track of what goes where,pictures are a must,a manual is really,really helpful.Then the brake line goes into them from the backside,remove that(you will probably need to work it a bit,they're usually pretty tight.A manual is really really helpful.A set of flare nut/line wrenches will help keep from stripping the fitting.Then there are two bolts that hold them to the backing plate.A manual is really really helpful.Some applications are left/right specific.Installation is the reverse of removal.A manual is really really helpful.Make sure the brake pads have not gotten brake fluid on them,if they have you shoud replace them.You might get them clean enough with brake cleaner but if you don't you have to tear it all back down.
BTW Did I mention,A manual is Really Really Helpful?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-02-2013, 09:27 PM   #3
SS Tim
SS Tim's Avatar
You can download the service and overhaul manuals.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 08-03-2013, 07:21 AM   #4
cdowns
cdowns's Avatar
only take one side apart at a time// so when you have the new cylinder in place and have to put back together you can use the other side as a referance of how it is assembled
Old 08-03-2013, 12:14 PM   #5
GRX
GRX's Avatar
^^ this. A digital camera is handy too.
When it comes time to bleed the system you might consider some "speed bleeders". Makes the job amazingly simple.
http://www.summitracing.com/search/b.../?autoview=SKU
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-10-2013, 10:14 AM   #6
Avalance1
Old 08-10-2013, 11:23 AM   #7
leddzepp
Moderator
leddzepp's Avatar
This is how its DONE:
http://www.pbase.com/nufsed/drumbrake
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
