Old 08-05-2013, 09:32 PM   #1
cjohnson6772
cjohnson6772's Avatar
need a part number or cross reference - a/c accumulator/filter/drier
I finished my ls swap and finally got my '01 truck compressor running and working with my aftermarket a/c unit. And then the compressor dies. Go figure. I have a 5 hr trip coming up Thursday and I desperately need to find a new filter accumulator in town tomorrow. My hoses are configured for a accumulator that has two male insert o ring 3/8 ends. My trinary switch is located elsewhere so that isn't an issue. Since this is an aftermarket unit I haven't found anything in town. Amy ideas what vehicle I can cross reference from? Again:
2 3/8" od
6 1/2" long
Two male insert o ring 3/8" fittings
Must be in stock. No time to order.
Thank you in advance
cjohnson6772 is offline   Reply With Quote
Old 08-05-2013, 10:50 PM   #2
70cst
70cst's Avatar
Re: need a part number or cross reference - a/c accumulator/filter/drier
Here is a bump ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-05-2013, 11:40 PM   #3
cjohnson6772
Originally Posted by 70cst View Post
Here is a bump ...
thanks for the bump. pretty excited about the opportunity of a long road trip, but the potential of no a/c is raining on my parade
Old 08-06-2013, 12:08 AM   #4
cjohnson6772
Old 08-06-2013, 12:40 AM   #5
farmall
farmall's Avatar
http://www.napaonline.com/Catalog/Ca...230_0140234393
This was the second one down on the web site.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 08-06-2013, 12:50 AM   #6
cjohnson6772
When I searched their site earlier, the site was messed up and would only show the first page. The drier you listed has female fittings, but I will look again for the male fitting equivalent.
Old 08-06-2013, 01:01 AM   #7
farmall
farmall's Avatar
Just take yours in to NAPA.
Good Luck in your search.
Old 08-06-2013, 01:08 AM   #8
hotrod100
hotrod100's Avatar
This one will work and should be in stock at any Freightliner dealer or truck parts store. Napa may even be able to cross it over for you. The parker/Freightliner part number is A22-14425-002 and it fits Freightliner FLC and FLD series trucks. The switch port has a Schrader valve in it so you don't have to worry about it leaking.
My build thread.
hotrod100 is offline   Reply With Quote
Old 08-06-2013, 07:00 AM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: need a part number or cross reference - a/c accumulator/filter/drier
From what I have learned you don't need the dryer [sightglass] if you are running the acumalator in the system. If you have swapped over to 134-A you really don't need it because it want take as much 134-A as it did R-12 so it's always going to have bubbles in it when watching it. So if u fill it up to the point of no bubbles it's over filled and the AC want work as good and can cause compressor failure.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-06-2013, 07:38 AM   #10
MARKDTN
I thought I have read that you can't use the stock compressors because of the variable ratio guts? That they would last a while and then die. Thought you had to use an aftermarket compressor on an LS conversion?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-06-2013, 08:04 AM   #11
Bigdav160
Bigdav160's Avatar
Drier or accumulator is metering device dependent.
Driers are used with expansion valves because they want bubble free liquid refrigerant so a drier is placed on the high side.
Orifice tubes don't care about bubbles but need an accumulator on the low side to prevent liquid from getting to the compressor.
I think the LS truck compressors are fixed displacement.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-06-2013, 11:47 AM   #12
cjohnson6772
This is correct.
Local parts house had something close and looting through the catalogs. Hoping to have it by end of day.
Old 08-06-2013, 12:24 PM   #13
truckdude239
truckdude239's Avatar
http://www.napaonline.com/Catalog/Ca...118_0333709307
TWD MEI7118
/C Filter Dryer Fitting Type[s] : O-Ring
A/C Filter Dryer Inlet Fitting : #6 (3/8") Male O-Ring
A/C Filter Dryer Length : 8"
A/C Filter Dryer O.D. : 2-1/2"
A/C Filter Dryer Outlet Fitting : #6 (3/8") Male O-Ring
A/C Low Pressure Switch Thread Size : None
Compatible Refrigerant Type : R12 / R134a
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-06-2013, 01:37 PM   #14
john
member #16
john's Avatar
I'm confused. Do you need an accumulator? (low side) or
filter dryer receiver? ( high side).
You say you need an accumulator but show pics of dryers.
Andy4639 shows an accumulator in his pic.
john is offline   Reply With Quote
Old 08-06-2013, 02:04 PM   #15
Andy4639
Old member
Andy4639's Avatar
When I swapped all my stuff over I used the acumilator system with orffice tube instead of the old POA valve and drier. More effienct so I was told at the time. I was told not to use the drier because the 134-A would take less freon in the system than the old R-12 did so there would always be bubbles in the system and the window on the drier was to look for bubbles with R-12 and keep filling until no more bubbles. Either one can be used but I perfer the newer stuff that was made for the 134-A system.
I bought a new compresssor because the old A-6 never worked well with the cycling the system and 134-A freon + a new condensor for expansion also.
