Old 08-09-2013, 11:46 PM   #1
steves1967
steves1967's Avatar
Disk Brake Shield Seal?
I pulled the stock spindles off today, including the disk brake shield. There was a cork gasket between the shield and the spindle. I cant seem to find replacements anywhere. Are they really needed? What are they called? Couldn't find anything in LMC either.
Thanks,
Steve
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 08-09-2013, 11:51 PM   #2
wgeyer88
Re: Disk Brake Shield Seal?
I believe the only purpose they serve is to damp vibration and avoid rattles. Can't help you with the name, sorry!
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 08-10-2013, 12:52 AM   #3
67c10rustbuket
67c10rustbuket's Avatar
ECE sells them for a whopping $2. Here is a pic with their part number. look under the option drop down box under disk brake backing plates. I could not find anything on Autozone etc. either
http://www.earlyclassic.com/catalog.aspx
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-10-2013, 07:23 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Disk Brake Shield Seal?
Do as I did. Go to parts store and buy the cork gasket and make as many as u want.
They also have black rubber gasket material to.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
