What's this
Do you guys know what the little orange fitting is. Looks like there were little hoses going there. It's a 1978 inline 250. It's right below the lifter cover and above the starter to the right. Want to know if I can take it out or what ?? Posted via Mobile Device |
Re: What's this
What are those weird, bolted down plates in between the heads, and the... well what is below them??
#3 | |
Re: What's this
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper.
Re: What's this
Yes, it's a thermal vacuum switch (TVS) that was originally plumbed with vacuum lines connected to the early fuel evaporation (EFE) valve (aka heat riser valve) on the exhaust manifold.
If you no longer need the EFE valve for emissions testing/inspection and/or cold weather driveability, you can remove that TVS and plug the hole with an appropriate size pipe thread plug. |
Re: What's this
Those two plates are pushrod covers
Re: What's this
Thanks guys that little piece had me stumped. I'll take it off.
Re: What's this
hey, straightsix. i have a 292, and i removed a bracket from the passenger side that connected from the top motor mount bolt to the alternator. now it wont fit. i noticed you dont have that bracket. just curios if you ran into the same problem or if the 250 did not come with bracket. also what blue is that?! i bought a chevy blue and its not the same color. sorry to bump the thread. just dont come across straight sixes that much around here.
79' c20 std cab 292 3speed granny - daily driver. 77' c30 std cab 454 th400 4.10 - fathers truck then mine. 95' ford bronco 302 4speed overdrive. 2002 mustang auto v6 - girlfriends daily driver. Debt just means that you had more fun than you're suppose to have |
Re: What's this
No I never had that bracket curious to see it what it looks like. And the paint on the engine is gm blue. I bought a couple cans from Pepboys I painted break booster power steering pump thermostat housings and heater on firewall
| Bookmarks |
