Old 08-31-2013, 02:41 AM   #1
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
tilt column
Is the 1967 standard column turn signal harness wiring the same as a 1972 tilt column. The reason I ask is when I pulled the 67 column the wiring harness on the column had a straight adapter to the horse shoe one under the dash. And the tilt column I put in did not need the adapter to fit the horse shoe plug under the dash. Did I explain the right.
Thanks.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 08-31-2013, 04:40 PM   #2
Mr Chevorlet
Rusty Nuts
Re: tilt column
I have looked for other threds but maybe I am not looking in the right places. Any help or anwsers I thank you. In the mean time I will keep searching .
Larry
Mr Chevrolet
Old 08-31-2013, 05:11 PM   #3
sprint_9
sprint_9's Avatar
Re: tilt column
Someone might have put a later model turn signal switch in your truck at some point.
The later model switches had the flat connector, earlier models had the half moon. Either will work if you have the correct adapter.
Does this help?
sprint_9 is offline   Reply With Quote
Old 08-31-2013, 05:28 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: tilt column
U should be fine. The half circle is the correct one for our trucks. The flat one was for later years but with the adapter they work fine. U are ahead of the game if the tilt has the 1/2 round already.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-31-2013, 10:30 PM   #5
Mr Chevorlet
Rusty Nuts
Re: tilt column
Ok thanks guys. If I have a issue with turn signals it must be a ground problem.
Larry
Mr Chevrolet
Old 09-01-2013, 12:17 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: tilt column
More than likely yes a ground issue!
