Between Trucks...
just rebuilt top end on my 350...
stainless valves, ported the heads, cam,edelbrock victor intake, liquid damper etc. bottom end only has 4000 miles on a fresh rebuild... but any way head lights didn't work after i got the motor back in... sprayed out the light switch w/wd-40 and lights worked.. then they went dead again, figured it was the switch...replaced switch, still no lights... no voltage at the lamp sockets...
Beat it to fit, Paint it to match...
its all about the +6 inches
Concentrate on the wires at the switch...shorted or corroded.
Then again, it coulda been coincidence that they worked after a cleaning. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! ![]() Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
huh?
![]() Join Date: May 2000
Check your floor dimmer switch as well, when the one in my 66 C/20 went bad, the lights wouldn't work at all, but the dimmer switch still operated normally
68
___________________ 1968 C10 Short Step, back in the fold permanently. 2015 RAM 1500 QC RIP El Jay |
Between Trucks...
thanks...
a friend of mine suggested the dimmer switch as well... we'll see whats up in the morning
| Bookmarks |
