At the body shop.
drop shocks
Searched with no luck.
Need a part # for shorter shocks for a 3" drop coil. Thanks in advance Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
Re: drop shocks
I've had the same difficulty on other vehicles. Usually its some kind of special shock or a shock off of a much lower vehicle, that will work for lowering the one you're working on. Then there's the valving...
Re: drop shocks
Relocating the upper mounts higher means using off the shelf parts designed (& valved) for your C10 app.
Re: drop shocks
Haven't run drop shocks on mine yet and I'm doing fine
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
At the body shop.
Re: drop shocks
The shocks are bottomed out.
bro n laws 1 ton to 1/2 ton swap and drop. Was looking for some shorter one. Guess of time to research Monroe catalog. Thanks Posted via Mobile Device
Old Heap Driver
Re: drop shocks
I used shocks fitting a 1950 Chrysler on the front of my C-10. But, I'm running drop spindles and bags, your needs may vary.
I think CPP makes a bracket to raise your upper shock mount.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Re: drop shocks
At the body shop.
Re: drop shocks
![]() 4X4 brackets on my 73 haven't had any luck finding a set at the pic n pull. Posted via Mobile Device
Re: drop shocks
Those are off of the quad shock 4x4 trucks
At the body shop.
Re: drop shocks
Yep.
No luck finding a set. Posted via Mobile Device
Re: drop shocks
Have some on my k5. But I'm going to used them haha. Doesn't Nate (porterbuilt) make them?
Re: drop shocks
There's alot of the airbag guys that sell em.(like AVS or Porterbuilt) When I had a 4.5/7 static drop I never needed a "different" shock. Just new ones, cause they were wore out.
Posted via Mobile Device |
#13 |
Re: drop shocks
the stock length shock should get you well into the steel bump stop/spindle stop under the rubber bump stop. are you sure its not just hitting teh bump stops?
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#14 |
At the body shop.
Re: drop shocks
They're gone altogether.
| Bookmarks |
