Old 09-10-2013, 05:49 PM   #1
the_69_C10
Lowering Questions
I know it's been asked a thousand times but....
I'm going to lower my truck 4/6 hopefully! I'm not gonna do a C Notch because many people say I don't need it. And My Welding Sucks. So ECE has a 4/6 but with front spindles, Hotchkis has a 4/6 with just springs. Will the Hotchkis kit be just as good? I really don't want to swap spindles yet. Thanks in advance
You guys mind checking out my thread? Not much there, I'm going to gt more pictures up soon! Sorry!
1969 C-10 SWB Project
2002 Chevy Silverado Ext Cab LS
Build Thread--> "Start of Something New"
http://67-72chevytrucks.com/vboard/s...d.php?t=557900
the_69_C10 is offline   Reply With Quote
Old 09-10-2013, 07:15 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Lowering Questions
Here, I'll change your mind on the C-notch. It's so easy a caveman can do it... so I bought one. The Porterbuilt C-notch is the way to go from my own experience installing the one piece c-notch. This setup takes the guess work out of the installer from wondering if the notch is lined up right under your rear axle and the two piece design allows the first plate that bolts on the frame to be used as a template which makes cutting the notch worry free. The second plate of has the notch and it just slides into place and bolts up. I have installed a C-notch before and it was a hack job to say the least, I had to weld up some sections where I cut to much material out of the frame.
Scott
sduckworth13 is offline   Reply With Quote
Old 09-10-2013, 07:17 PM   #3
sduckworth13
Here is a link
http://www.porterbuiltfabrication.com/?p=385
Scott
Old 09-10-2013, 07:20 PM   #4
Pro Performance
Pro Performance's Avatar
I would lean towards the ECE, since it uses spindles. I my opinion, this is the better way to go, so that you are not using the spring to get the complete 4" of drop. As for the c-notch, it does add a little more clearance, depending on what you will be using the truck for and if you will be hauling things. Scott is right, the PB c-notch does make it simple, because you can use one of the pieces as a template. It is built extremely well and very heavy duty. I would suggest the PB notch if you do decide to add one.
We have heard good things about the ECE kit.
Pro Performance is offline   Reply With Quote
Old 09-10-2013, 07:26 PM   #5
the_69_C10
Does soindles make a difference then all 4" with springs? Thanks Guys.
Old 09-10-2013, 07:29 PM   #6
the_69_C10
On the Porterbuilt kit, what comes welded together?
Old 09-10-2013, 07:30 PM   #7
Pro Performance
The spindle will lower the truck 2" without effecting suspension geometry or ride quality. A 2" spring will effect it less (vs. a 4" spring), since the arms stay closer to the factory position. Of course, an alignment will bring it back to where it needs to be. In some cases. it can be difficult to align using a 4" spring, since the control arms are much farther up and away from the factory ride height position. I don't have personal experience aligning a truck with a 4" spring, but I have heard of people having issues. Maybe someone with 4" springs can shed some light on this.
Old 09-10-2013, 07:32 PM   #8
Pro Performance
Each piece is welded to create it, but the 2 pieces themselves don't get welded upon installation. They just bolt to the frame.
The additional pictures here show it...
http://www.azproperformance.com/Port...0-C-Notch.html
Old 09-10-2013, 07:34 PM   #9
the_69_C10
So there is no welding on my part? Just trace the pattern and bolt it up? Are in struction included
Old 09-10-2013, 07:34 PM   #10
Fitz
HUGE difference. The spring only approach really screws up the front end geometry. In short your truck will hangdle like a pig and I suspect you will be breaking tie rod ends. At the very least you will need a new pittman arm. 2 in drop in the spindle and 2 in drop in the spring is a much better way to get 4 in lower.
Fitz is offline   Reply With Quote
Old 09-10-2013, 07:36 PM   #11
Pro Performance
No welding on your part. Trace, cut the frame, drill holes & bolt it in. No instructions are included, but I can help you if needed. It is very straight forward, and they fit on the frame only 1 way really.
Old 09-10-2013, 07:38 PM   #12
the_69_C10
Fitz- Thanks, will definitely consider that.
Pro Performance- That's awesome I think you just sold it to me.
Old 09-10-2013, 07:42 PM   #13
Pro Performance
Sounds good! and very glad I could help. Just give me a call when you are ready.
- Travis
Old 09-10-2013, 07:46 PM   #14
67 chevelle
67 chevelle's Avatar
6-4 is pretty low , as all have suggested drop spindles are the way to go up front , and c notch in back with the springs and shocks 6 is too much IMO to do without a c notch , 5 yes 6 no
67 chevelle is offline   Reply With Quote
