gauge cluster cleaning?
So the other day I pulled apart my gauge cluster to clean/fix bulbs and gauges that werent working.
How do you clean the gauges themselves without smearing the painted letters/numbers? I tried using a dry paper towel but it started smearing just a tiny bit. Thanks.
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
Getting Old; Going Broke
Re: gauge cluster cleaning?
Compressed air and a clean and dry detail brush/paint brush.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
While u have it out I would suggest, in my humble opinion, to get some chrome rattle can and take your gauges out then spray the back drop. It will make it a lot brighter for way cheeped.
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
#4 | |
78K & 79C Jimmys
and paint the front too the metal rusts I used air and Qtips for dusting,dry paper towels carefully tho as too hard will leave swirls on the face I used green dash bulbs in it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-15-2013 at 10:16 AM. |
#5 | |
78K & 79C Jimmys
and i added a second colour red to the 78
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Silver paint and LED 194 bulbs. I got mine from superbrightleds.com. And obviously a sawzall.
Few things in life will make you look stupider than putting a dollar sign after a number. |
The clear part can be shined up with a headlight buffing kit.
78K & 79C Jimmys
not till i put the radio in lol
Thanks for the responses yall.
Did you ever have any problems with the circuit board on the back? Mine is falling apart.
Don't use chrome or silver paint, it will make the lighting worse. paint the cluster case gloss white, it'll increase the lighting dramatically.
I tried the chrome paint first, it turned out terrible, could barely see the gauges at night. I pulled the whole cluster apart again to replace the printed circuit, and I re-did the inside of the case with gloss white. Far better, with just the stock bulbs it was much brighter. |
#12 | |
http://coloradok5.com/forums/showthread.php?t=296187
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
#13 | |
78K & 79C Jimmys
#14 |
Motornut can you please give details on how you painted the gauge needles?
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
#15 |
78K & 79C Jimmys
I had them out of the cluster
cut squares of printer paper and a thin slit to the middle slide under the needle, pulling the pin into the slit turn paper as needed Posted via Mobile Device
#16 |
Thank you Motornut I was wondering if something like that might work.
| Bookmarks |
