Old 09-17-2013, 09:02 PM   #1
heavyduty67
bought 1964 stepside
just bought my 1st c10. don't know where to start to restore it. needs a lot of work, but im going to take my time and do it right. hope to do a build thread. looking for a bench seat.
heavyduty67 is offline   Reply With Quote
Old 09-17-2013, 09:25 PM   #2
1963c-10
1963c-10's Avatar
Re: bought 1964 stepside
welcome and congrats on the new purchase. get it to stop, start and steer properly 1st, then worry about the rest. the bench seats are pretty easy to come across, where in nc are you? im in fayetteville....there is a pretty large nc crowd here.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-18-2013, 07:08 AM   #3
Old Bleu
Old Bleu's Avatar
Congratulations! I got mine in May of this year. +1 on what 1963 said. I started with the brakes on mine, and discovered that it had no rear brakes, the rubber hose from the steel brake line to the rear axle was mush inside.
Old Bleu is offline   Reply With Quote
Old 09-18-2013, 08:45 AM   #4
wayno
Congrats man - look forward to seeing your build. I have a 64 step-side in pieces in the garage right now - finally starting to get the old girl put back together. Can wait to see pictures.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 09-18-2013, 10:38 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Welcome! Can't wait to see the progress! I own a 64 also that is being used as a parts truck. Lets us know if you need any info. Were here for ya, and pictures are always welcome! Thanks and good luck. T.J. I got mine running first, then got some brakes and checked the fluids and got some tires.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-19-2013, 12:21 AM   #6
Captainfab
60-66 Nut
Welcome to the forum
I agree with 1963c-10
Old 09-23-2013, 02:13 PM   #7
heavyduty67
need some info on front frame cross member under the radiator. can it be changed, and where can i get one.
Old 09-23-2013, 02:39 PM   #8
1963c-10
1963c-10's Avatar
Are you referring to the front cross member (holds the a arms and front suspension) or the radiator mount? Porterbuilt sells a replacement radiator crossmember. As far as front suspension crossmembers you have several options depending on what you are trying to do.
Here is the porterbuilt radiator support crossmember link: http://www.porterbuiltfabrication.com/?p=340
Old 09-23-2013, 02:50 PM   #9
T Smith
T Smith's Avatar
You came to the right place, welcome to the addiction!
T Smith is offline   Reply With Quote
Old 09-23-2013, 10:05 PM   #10
65c10restomod
65c10restomod is offline   Reply With Quote
