Old 09-18-2013, 05:34 AM   #1
hyper77
Exhaust System
I've got a 1977 shortbed stepside, it has a small block with stock manifolds and a TH400 trans. Dropped it 6 out back and 4 in the front. Truck is a new build. Thought I'd forego doing the exhaust on my own and went to a recommended shop for a dual exhaust install. It turned out to be a real bad experience so I'm going to redo it myself. I'm hoping some of you can point me toward some kit options I can buy and install myself. Looking for something quiet so I can take this truck on longer outings. Any picture of stuff you've done would also be appreciated. Thanks for the help, Jim M.
hyper77 is offline   Reply With Quote
Old 09-18-2013, 09:05 AM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: Exhaust System
As far as kits it just depends on what you want exactly 2.5" should be fine with a stock set up. The link I'm attaching is a link to summitracing.com and it's all the exhaust systems they have for our trucks. Now typically I've learned the larger the muffler the quiter it will be, it doesn't show on here but you could even search magnaflow and flowmasters main websites and might find some kits there.
http://www.summitracing.com/search/d...1977/model/c10
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 09-18-2013, 10:12 PM   #3
Blackpony
Blackpony's Avatar
Re: Exhaust System
if you are handy with a welder and have a chop saw available, summit sells a universal kit with a couple of u bends, 45, 90, straights, etc and you can get them with a mid pipe. I would suggest getting one of those kits and just fabbing your own system.
Blackpony is offline   Reply With Quote
Old 09-19-2013, 09:20 AM   #4
stampy
stampy's Avatar
Re: Exhaust System
Is installing an H-Pipe worth the effort?
stampy is offline   Reply With Quote
Old 09-19-2013, 11:23 AM   #5
77ChevySharkBite
Re: Exhaust System
Well are you planning on running a true dual exhaust or just single muffler with like a 2 in 2 out?
Korwin
Old 09-19-2013, 11:28 AM   #6
stampy
stampy's Avatar
Re: Exhaust System
True duals. Hooker comp headers, probably DynoMax or Magnaflow mufflers.
Old 09-19-2013, 11:30 AM   #7
77ChevySharkBite
Re: Exhaust System
No reason to do a H pipe then, just put the true dual exhaust and call it done.
Korwin
Old 09-20-2013, 03:48 AM   #8
andrewmp6
Re: Exhaust System
I would do a h pipe if you can it helps even out the exhaust on both sides and gives a little more power.
andrewmp6 is offline   Reply With Quote
Old 09-20-2013, 08:10 AM   #9
77ChevySharkBite
Re: Exhaust System
I don't want to start a big arguement or anything I just want to know how doing an H pipe on a true dual helps it. Cause to me it seems more or less that it would cause more restriction than anything.
Korwin
Old 09-20-2013, 08:20 AM   #10
bnoon
Re: Exhaust System
X-pipes and H-pipes have shown to be worth power on dynos pretty much ever since someone thought of doing it. It helps merge high pressure pulse areas and improves scavenging on dual exhaust. You wouldn't need an X or H on a single exhaust so I'm not sure how you're wondering how it wouldn't help on true duals... They wouldn't even be around if they weren't working on dual exhaust.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 09-20-2013, 08:44 AM   #11
77ChevySharkBite
Re: Exhaust System
That is very but I was told it wasn't necessary to do it, that it wouldn't be giving me that much more power. Would it also depend on your set up to or is it just an overall you should do an x or h pipe? Cause on my truck I have longtube headers, and flowmaster 10 series mufflers which that combo is pretty much the equivalent of running open headers just toned down a couple notches.
Korwin
Old 09-20-2013, 09:34 AM   #12
Edahall
Re: Exhaust System
Jim, since you asked, I'll tell you how I do it. I'm assuming you also want free flowing as well. What I do is install 2 different types of mufflers to cancel out the high frequency and low frequency sound. I accomplish this by using a good quality glasspack such as Thrush and a good quality baffle type muffler such as Flowmaster. The Flowmasters do good at canceling out the low frequency sound and the glasspacks do good at canceling out the high frequency sound. For as quiet as possible, install long glasspacks or install 2 shorter ones in series.
I've done this on all my custom exhaust work and it always works out great. Only thing is you do end up spending a little more for mufflers but the results are worth it. You can also tune your exhaust. If you want more low frequency, you would use a baffle muffler with less baffles. If you want more high frequency, you would use a shorter glasspack. And yes, use an H pipe or X pipe as previously mentioned. That too cuts down on the noise and makes your exhaust less restrictive.
If you're interested, I'll provide you some photos.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 09-20-2013, 10:06 AM   #13
streettruck1
Re: Exhaust System
if i was u since u want quite is just go with two thrush mufflers thats at advance or autozone they are 26 bucks each run 2 1/2 pipe with turndowns after muffler unless u like full exhaust.my family member just put one on his 02 chevy it is really almost stock sounding but has a light tone thats only heard outside the truck.im a flomaster guy the hushpower line might work for you the are very mild sounding and good for tight space.
streettruck1 is offline   Reply With Quote
Old 09-20-2013, 10:11 AM   #14
streettruck1
Re: Exhaust System
http://shop.advanceautoparts.com/web...thrush+muffler
