Throttle linkage...
tomorrow I am replacing my stock intake manifold and 2 bbl carb with a new edelbrock carb and performer manifold.
will the throttle linkage most likely lineup or might i have to change it? the engine is a smallblock v8 (305). |
is this just one of those questions that defies answering?
i'm not looking for a guarantee in writing.. i just wanna know if the throttle linkage in a '69 C/10 *should* match an Edelbrock carb... Anybody even care to venture a guess? |
The throttle rod should line up and be long enough. You will probably have to adjust it longer. There should be a hole in your carb linkage for the trunion. The only question that I have would be if a bushing were needed or not.
Jim |
Resident Curmudgeon
![]() Join Date: Dec 1999
Did same thing on a 68. The rod linkage may require small adjustment, but if original, it'll be threaded to accomodate adjusting. You may have to drill the hole in the linkage on the carb a little larger to accomodate the trunnion. As close to a slam dunk as it gets (as long as your linkage parts are OE)
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
its all about the +6 inches
I had to drill out my throttle linkage to mount up my Performer carb. Mine was originally a V-6 truck and I asume the rod is original being how pathetic the last owner was.
There is quite a range of useable space on that rod, i was even able to use the stock small block one on my caddy swap. |
