Old 09-30-2013, 12:42 AM   #1
1slo_camaro
350 to 454 swap
Hey guys. so i know i started another thread about a sbc vs bbc. i just got offered a 454 running for 350$ and am really contemplating picking it up. my stock 350 is starting to make some noises that I am not very happy with. what all would be envolved in this swap? obviously exhaust. but what are the dire necessity for this? i am looking for a weekend swap. i plan to pick the motor up clean it up a little with a wire brush and all. pull my sbc clean the engine bay up a little and throw some paint on her then drop the motor in so i am looking for the bare essentials for right now to get it back on the road
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 09-30-2013, 04:07 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 350 to 454 swap
Big block radiator and shroud. Hoses and maybe a big block pattern torque converter
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-30-2013, 05:50 AM   #3
1slo_camaro
Re: 350 to 454 swap
really that simple?...... now can i run the sbc radiator and just be easy? also the weather here in jersey is down in the 60s on most days so its already gonna be running cooler then normal.
I had planned on replacing the belts and hoses anyway and probably the water pump while its out and readily available.
Old 09-30-2013, 08:39 AM   #4
anubisani
anubisani's Avatar
Re: 350 to 454 swap
they use the same converter , the only dff... might be the stall
anubisani is offline   Reply With Quote
Old 09-30-2013, 10:37 AM   #5
geezer#99
geezer#99's Avatar
Re: 350 to 454 swap
Never that simple!!
Exhaust?
Headers?
Brackets for a/c if equipped?
Throttle linkage?
Power steering brackets?
Booster size?
Mounts?
Wiring?
There can be subtle differences in all those or more that make it more than a weekend project.
Old 09-30-2013, 03:03 PM   #6
INSIDIOUS '86
Re: 350 to 454 swap
Yes but a big block will have a bigger bolt pattern on the flywheel in most cases. I've done the sbc-bbc swap twice now the issue has come up. Luckily they both are th350 and th400 vehicles which use the same converter. Plenty of them in CL
Old 09-30-2013, 08:05 PM   #7
Rubble
Re: 350 to 454 swap
I done the reverse swap last winter for a buddy's K25,454 to a 350.The 350 had all the accessories still on it,alt,power steering pump& brackets & ex manifolds. It was fairly strait forward,don't think there was any wiring that had to be changed either.Far as rad goes,my 80 K20 had a bb swap done years ago & they kept the 350 rad,no cooling problems with it.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 09-30-2013, 09:58 PM   #8
meatwagon83
meatwagon83's Avatar
Re: 350 to 454 swap
Originally Posted by geezer#99 View Post
Never that simple!!
Exhaust?
Headers?
Throttle linkage?
Booster size?
Mounts?
Wiring?
linkage? probably a cable, so ,the same
booster size, really? its the same
mounts, same
wiring, same, hell they even use the same distributor!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 09-30-2013, 10:13 PM   #9
66/87chevy
Re: 350 to 454 swap
I just did this swap. The motor mounts are the same, throttle cable same, wiring is no different same alternator.
You will need BB flex plate, BB pulleys & brackets, hopefully all that comes on the motor. If so that will make things easier.
I did install a BB radiator.
66/87chevy is offline   Reply With Quote
Old 10-01-2013, 01:08 AM   #10
1slo_camaro
Re: 350 to 454 swap
yes it has all the acc except for the ps.... can i use my 350 power steering pump?
ill be ordering a set of ceramic long tubes from summit for 225$ and building my own exhaust.
Hell these things only need like 4 wires to run.... I got this... lol
this isnt my first motor swap or custom swap. i just have not done this exact swap and was trying to get some insight from people who have done it already. and I believe it still have the flexplate on it so thats huge if it does
Old 10-01-2013, 01:17 AM   #11
Rubble
Re: 350 to 454 swap
I'm pretty sure the pump is the same,just different mounting brackets....
Old 10-01-2013, 01:31 AM   #12
1slo_camaro
Re: 350 to 454 swap
knowing my luck that will be the only damn thing that will hold me up from being able to drive it haha.
Old 10-01-2013, 09:20 AM   #13
bnoon
Re: 350 to 454 swap
Don't forget, you can get a dual pattern flexplate and use either converter bolt pattern! If you already have a high dollar converter, this may be a cheaper option for you. Also in case people don't know, the same converter will stall slightly higher (few hundred RPM) on a big block in most cases from the added low end TQ.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 10-01-2013, 11:48 AM   #14
anubisani
anubisani's Avatar
Re: 350 to 454 swap
same pump diff brackets he is right
Old 10-01-2013, 12:10 PM   #15
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Re: 350 to 454 swap
The first thing you need to do is put in a much bigger fuel tank...
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 10-01-2013, 02:07 PM   #16
INSIDIOUS '86
Re: 350 to 454 swap
I think outs was single pattern which was the issue. And being that a 454 is external balance it's not a great idea to change them
Old 10-01-2013, 02:54 PM   #17
Rubble
Re: 350 to 454 swap
No kidding!!!
Old 10-01-2013, 04:24 PM   #18
bnoon
Re: 350 to 454 swap
I've never had an issue as long as I got an externally balanced flexplate. Flexplates from the smaller BBC are internally balanced so can't use those. One of our older trucks got a 700R4 with a dual pattern flex and a stock S-10 converter and ran for years.
