Old 09-30-2013, 01:58 PM   #1
Steve Cole
Heater box removal tips
So the PO installed my heater core upside down. (3/4" line on the bottom) I need to look in there anyway to see what else needs attention so I am going to remove the heater box. I need to know if the box can be removed without disconnecting the hood hinge. I know the inner fender needs to come down. I will be working by myself and I see potential for disaster if I take one side of the hood loose. Any tips to keep me from messing something up? Thanks!
Steve Cole is offline   Reply With Quote
Old 09-30-2013, 02:07 PM   #2
aedcustoms
aedcustoms's Avatar
Re: Heater box removal tips
when i removed mine i just removed the two rearmost bolts on the hood hinge i believe, and loosened the front bolt. i did not remove the inner fender and with a little manuvering i got it out
1969 C10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=580422
1981 C10 SWB
1995 ECSB Bagged
aedcustoms is offline   Reply With Quote
Old 09-30-2013, 04:14 PM   #3
NC67Chev
NC67Chev's Avatar
I just did mine. I chose to leave the front bolts in the the good hinges and lowered the hood down on a broomstick resting on the floor. It was a pain to get the lower outer bolt/screw, but its done.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 09-30-2013, 08:11 PM   #4
Daddy Brim
Daddy Brim's Avatar
Make sure you put a towel under the corner of your hood so it will not scratch the paint
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-30-2013, 09:37 PM   #5
quick60
quick60's Avatar
I took the hood and inner fenders off.
Once I got inside mine I found the inside metal on my heater box was badly rusted so I found one here (see link) in case you need to do the same. Non AC only though.
http://woodallindustries.com/product.php?skcid=1001819
quick60 is offline   Reply With Quote
Old 10-01-2013, 12:09 AM   #6
Steve Cole
Thanks for the good tips guys.
Aedcustoms, did you have any hood alignment issues afterwards ?
Old 10-01-2013, 12:25 AM   #7
wreckedchevy
wreckedchevy's Avatar
out at the farm they cut the my heater box in too then used fiberglass resin to seal the 2 halves back together.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 10-01-2013, 10:14 AM   #8
Steve Cole
Thanks, but I don't believe I will be going that route.
Old 10-01-2013, 09:58 PM   #9
pritch
pritch's Avatar
This is how I rebuilt mine:
http://67-72chevytrucks.com/vboard/s....php?p=5924953
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
