Old 10-03-2013, 09:10 PM   #1
HotRodPayne
Data link connector??
Has any one added a Data link connector to your truck harness?
HotRodPayne is offline   Reply With Quote
Old 10-03-2013, 10:02 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Data link connector??
Pretty sure almost everyone has, what's your question?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-03-2013, 10:04 PM   #3
HotRodPayne
Did your harness come with it or did you add it?
Old 10-03-2013, 10:28 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my custom harness had one
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-04-2013, 01:31 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If by data link you mean obdII, then you pretty much require one. No way to tune it without getting into the pcm.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-04-2013, 05:39 PM   #6
ls1nova71
ls1nova71's Avatar
The ALDL connector is part of the dash harness in a factory vehicle, if you're modding a factory engine harness to stand alone, then you will have to add it. Its pretty simple just a constant power a couple of grounds and a single data wire to the PCM.
Old 10-04-2013, 06:55 PM   #7
HotRodPayne
Thank you
Old 10-05-2013, 11:21 PM   #8
Root2812
Root2812's Avatar
Could you tell us which wires? I have the 5.3 and I want to modify my harness. You said a single data wire but I see data wires for blue pin outs 14, 15, and 58. 58 says data to obd2 but the others say data too. What do th other two do? Please clear this up for me. I used this http://www.lt1swap.com/99-02_vortec_pcm.htm
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 10-06-2013, 09:50 AM   #9
ls1nova71
ls1nova71's Avatar
What year is your 5.3? The 14 and 15 are for 2000-2002 drive by wire harnesses,. I believe they may go to the TAC module, but I'm out of town at the moment and can't check for sure. But anyway, the 58 dark green wire is the one that goes to the ALDL, at least on a 2000-2002.
Old 10-07-2013, 11:29 PM   #10
Root2812
Root2812's Avatar
Thanks. Mine is a 2000 drive by cable. I want to do my own harness modification but the 3 points that I am most confused on: the OBD2 (is ALDL the same thing?), check engine light, and electric fans. My motor has a mechanical fan that has to go for clearance.
I hope extending the topic isn't thread jacking
My 1950 Chevy build
Old 10-13-2013, 07:33 PM   #11
BigRed76
BigRed76's Avatar
I'm not trying to hijack this thread, but I just want to clarify all of the necessary wires for the DLC. This diagram from AllData (for 2000 5.3) shows pin 4 being a ground, and then pin 5 being a PCM ground. Can these just be the same body ground? The only wire I have from the PCM for the DLC is the dark green serial data wire, which will be pin 2 on the DLC.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 10-13-2013, 07:48 PM   #12
clinebarger
The Grounds can be connected to any good body ground, You have everything else figured out.
clinebarger is offline   Reply With Quote
Old 10-13-2013, 09:50 PM   #13
BigRed76
BigRed76's Avatar
Thanks clinebarger
Zach
