Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 10-04-2013, 07:36 PM   #1
palerider
palerider's Avatar
1963 K50 1.5 ton 10 hole rims
hello looking for info on locating 6 10 hole 8 3/4 bolt pattern 6 1/4 bore wheels not split rims for 63 chevy napco k50 truck ? I think this is right not sure cant find much info on these old timers anyone got any ideas? 20 inch on now split rims thankx
Last edited by ETsC10; 10-24-2013 at 10:06 AM. Reason: Removing WTB fom non-subscribing member
palerider is offline   Reply With Quote
Old 10-06-2013, 09:49 PM   #2
palerider
palerider's Avatar
Re: 1963 K50 1.5 ton 10 hole rims
Here's my truck
Old 10-06-2013, 09:52 PM   #3
palerider
palerider's Avatar
Old 10-08-2013, 12:06 PM   #4
mrolds88
Nice truck!!!!
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 10-08-2013, 01:04 PM   #5
palerider
palerider's Avatar
22.5 do you think they will clear I think I have found a place that sells them and you can get 10 in wide too. any thoughts???????
Old 10-08-2013, 08:28 PM   #6
aerotruk63
aerotruk63's Avatar
Now that's a daily driver!
Old 10-08-2013, 08:51 PM   #7
bojak
bojak's Avatar
Just love this truck. Way sharp.
bojak is offline   Reply With Quote
Old 10-24-2013, 12:06 AM   #8
JPBrecheisen
I am looking for a set as well. I found a place that will make them, but you'll need a deep wallet. They're $335 each. Apparently, the 8-3/4 10 lug bolt pattern was used only with GM medium duties, so wheels with that bolt pattern are going to be scarce. I am also looking since I've been told the RH-5s are dangerous and scary and should be avoided.
Here is some info that might help.
Wheel part number you'll need is 28160. That's an ACCURIDE wheel part number. ACCURIDE no longer makes them, but Wheels Now, Inc does. Their part number is the same only I believe it has a "WN" prefix or something like that.
Here is a link to their website. http://www.wheelsnowinc.com/
I talked to a guy there and he said the catalog has a mistake. The 28160 part number has the following features. R22.5x6.75W 10 LUG on 8-3/4 bolt pattern. The catalog says it has a different bolt pattern, but it actually has the 8-3/4.
Maybe you can find a used set of ACCURIDE wheels out there. There is a C60 in my area that has a full set of the single piece 22.5's but I'm certain the owner would not sell just the wheels to me. I will stop in this week and ask anyway. You never know.
Totally awesome truck BTW.
Not sure if this helps or not.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 10-24-2013, 07:18 AM   #9
palerider
palerider's Avatar
great help thanks nice truck you got too...Pale
Old 10-24-2013, 11:50 AM   #10
OldCreek
OldCreek's Avatar
You should make your way over to Stovebolt.com
There's a lot of big trucks and parts over there.
Good luck,
Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 10-24-2013, 08:16 PM   #11
haminator
haminator's Avatar
Wouldn't a 19.5 10 hole wheel work or is the circle too small on them?
haminator is offline   Reply With Quote
Old 10-24-2013, 08:29 PM   #12
palerider
palerider's Avatar
thanks great site
Old 10-24-2013, 08:33 PM   #13
palerider
palerider's Avatar
not sure Im still trying to put it all together being a 4x4 its a little different I think?? anyway keep me posted Im going custom if have to the electric company truck was moved so I could not get photos it was just what I was lookin for looked like 10 hole 20-22.5s x 10-12 and maybe 44s-46S not sure thanks.
Old 10-25-2013, 09:38 AM   #14
buggy5872
buggy5872's Avatar
Tt should work if it clears the brake drum but there are no tires available that are taller than 34". That truck would not look correct with that small of a tire.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1959 D860
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 10-25-2013, 08:20 PM   #15
haminator
haminator's Avatar
Thats a good point. Man I dig this truck.
Old 03-13-2014, 09:19 PM   #16
Bigasstrux
Bigasstrux's Avatar
Accuride catalog
Bigasstrux is offline   Reply With Quote
Old 03-15-2014, 02:12 AM   #17
michael bustamante
michael bustamante's Avatar
Ill look st a couple gm trucks here at the yard for you. Have you looked into shipping these things?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-22-2014, 03:33 PM   #18
factorystock
factorystock's Avatar
This is the period 22.5" 1 piece wheel to look out for.
factorystock is offline   Reply With Quote
