Old 10-05-2013, 07:28 PM   #1
Chevy3+3
Will Skyjacker 2.5" springs support big block?
I plan on bumong my 88 1 ton up about 2-3" in the front. I here many speak highly of Skyjacker springs and they make a 2.5" front lift spring set and rear block kit for a 1 ton. Since it is made for the 1 ton will it support the 454 alright? I don't want to spend the money if the springs will sag under the extra weight because I really want that 2.5" in height. The kits isn't cheap at $450.
Anyone have any suggestions for another front spring set? Does anyone know if the springs would be the same width as the stockers? I've heard sometimes they narrow the width of the spring and use bushings to take up the difference.
Chevy3+3 is offline   Reply With Quote
Old 10-05-2013, 09:46 PM   #2
donut
donut's Avatar
Re: Will Skyjacker 2.5" springs support big block?
I don't know the product, but when I'm forking over hard earned cash, I don't hesitate to contact the company and ask. If you have any problems, you'll have to deal with them anyway.
Hopefully someone can chime in with an opinion and/or other options. (or slid over to the 4x4 section)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-05-2013, 11:40 PM   #3
dieseldawg142
dieseldawg142's Avatar
the skyjacker springs will hold your 454 with no problem. i have 8" skyjacker springs in my crew for 7 or 8yrs now & they have only come down about an 1/8. they are 2 1/2" wide.
i'm running a 454 as well
dieseldawg142 is offline   Reply With Quote
Old 10-05-2013, 11:59 PM   #4
Chevy3+3
Okay. I am confused by what I will get in the kit. The kit is #C125CK. It says I will get a pair of 2.5" front spring packs and 2" lift blocks and hardware pack. The hardware pack says it only comes with 6 u-bolts? I figure I would need 8 new u-bolts but maybe I'm wrong. Then it says the lift blocks are for 1 Ton (except dually) which mine is a dually. I guess I should just call them.
Old 10-06-2013, 12:11 AM   #5
Rubble
I will have to check my crew tomorrow for sure,but I think there are only 2 u bolts on the front left hand side.The right has bolts going into the axle if I remember..Not sure about the lift blocks,but they shouldn't matter dually or srw.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 10-06-2013, 12:39 AM   #6
dieseldawg142
if your crew still has the d60, you will need 7 u-bolts & two 9/16 bolts on the pass. side, inboard.
like Rubble says, shouldn't matter 'bout the blocks, their one of the more universal parts, long as there as wide as your pack
Old 10-06-2013, 12:40 AM   #7
Chevy3+3
Well I will glance at mine in the morning. I just assumed everything used u-bolts but probably wrong. Thanks
Old 10-06-2013, 12:51 AM   #8
Rubble
Ya,I'm too lazy to walk out to the shop now!!!!
Old 10-06-2013, 01:08 AM   #9
dieseldawg142
here ya go, save you a walk Rubble.
4 U's for the rear & 3 U's & 2 bolts for the front
Old 10-06-2013, 09:40 AM   #10
LONGHAIR
The inner side of the Dana60 front axle will have 2 studs w/nuts going up thru the plate. These are usually replaced with bolts when the lift spring's thickness is greater than the original springs. It is not necessarily the best idea though, studs are better in this application.
The internal threads of the cast iron housing are inherently weak. When you use a stud, the threads only "see" the tension applied to the stud, not the torque.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-06-2013, 09:59 AM   #11
Rubble
Attachment 1159423
Thanx!!
