Old 10-13-2013, 01:50 PM   #1
i heart square bodys
i heart square bodys's Avatar
Tremec TKO swap
okay so im thinking of putting a tremec TKO in my truck. at the moment it is an automatic trans but i have a high hump for the floor so as far as that goes im safe. what im needing to know is more info on doing the actual swap. the website says any bellhousing off a 4 speed gm will work. id like to go with a hydro clutch of coarse and i dont know exactly what i need as id imagine there are different styles of bellhousings and clutches. im a noob haha. also will i need to lengthen my driveshaft ? aaaaand what do i have to do as far as putting the clutch pedal in as i have never done this (holes to drill etc) , thanks for anyone who can help !
1986 LWB c10 w/327 & vortec heads
i heart square bodys is offline   Reply With Quote
Old 10-13-2013, 06:41 PM   #2
LUCKIN-FOU
I'M NOT SCARED I HAVE A PLASMA
LUCKIN-FOU's Avatar
Re: Tremec TKO swap
I use Modern driveline they sell the kits for a hydo clutch, bell housings transmissions. what ever you need. Bruce is good 408/453/9800 bruce@moderndriveline.com
Lou Santiago
US Navy Retired/World Traveler
Car Builder/Welder/Airport Investigator
garageinsidertv.com [FORUM]
WORK IS FOR PEOPLE WHO CAN'T FISH. I GUESS I'M SCREWED BECAUSED I HATE FISHING.
LUCKIN-FOU is offline   Reply With Quote
Old 10-20-2013, 09:17 AM   #3
wraprail
wraprail's Avatar
Re: Tremec TKO swap
Look for brake/clutch pedals from a 87-91 for hydraulic or use 73-86 and convert to hydraulic using a wilwood or tilton 3/4 master. Make sure you use a car bellhousing not a truck. Pedals are a simple swap. Very straight forward.
wraprail is offline   Reply With Quote
Old 12-02-2013, 10:35 PM   #4
Re: Tremec TKO swap
why a car bellhousing over a truck one ??
Old 12-02-2013, 10:36 PM   #5
Re: Tremec TKO swap
and how hard is it to convert a mechanical bellhousing to hydro ?
Old 12-02-2013, 11:22 PM   #6
mongoose
mongoose's Avatar
Re: Tremec TKO swap
use a hydro throwout bearing
and if you use a truck housing youll need to buy or make a ring like this one, as the holes are different sizes.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 12-03-2013, 09:41 PM   #7
wraprail
wraprail's Avatar
Re: Tremec TKO swap
^^^what he said. The hole on the truck belhousing is too big for any of your performance transmissions. If you went with an aftermarket steel belhousing they only come with the small hole, as far as I know. You can avoid all this and the expense of the TKO, belhousing and everything else and find a T56. Yes it's not a TKO but is a lot cheaper. I found one from a 95 camaro at pic-a-part not long ago and paid $185 out the door. My early flywheel was $500 but you can find them for less. I used the old camaro clutch, came with a Hurst shifter, got a nice hurst stick on ebay for $30. Stock pedals, old used wilwood master. All in and now 20,000 miles ( its my daily driver) I don't have more than $800 into the trans total. Whats a TKO gona run $3500 +?
Almost forgot, $38 for f***ing clutch cover (pressure plate) bolts! Only ARP makes them and they r torque yeld one time use bull****.
