10-17-2013, 07:05 PM | #1 |
horn wiring question
Anybody know which wire powers the horn?
There is a green one that is cut at the bottom of pic and Two separate plastic connectors that arent doing anything Sorry so dirty I was able to jump a wire from the battery to make sure horn works |
10-17-2013, 07:30 PM | #2 |
Re: horn wiring question
the green wire is horn power
1972 K10 Stepside: SBC 350, TH350 Transmission, NP205, 4 inch lift, 33" tires. Frame Off Restoration 2011- Spring 2014 1971 K10 Stepside: SBC 350, TH 350 Transmission 6 inch Lift Kit 35'' tires SOLD 1970 K10 Parts Truck: SBC 350 for 1972, SM 465 Transmission |
10-17-2013, 08:05 PM | #3 |
Awesome, thanks
I'm getting the feeling its going to stay on once I connect it, why else would somebody slice the wire? (Has an old z28 wheel swapped in) |
10-17-2013, 09:50 PM | #4 | |
20' Daredevil (Ret)
Assuming it does stay on, there's also the possibility of a bad (stuck) horn relay. But you're probably right about the steering wheel being the culprit.
