A day late and $1 short...
Holley Mid Rise LS Intake P/N300-126
Has anyone seen this intake (Holley 300-126) actually installed and used? I can't find any builds that give info with part numbers for injectors and the like. Just wondering if anyone has seen it in use.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
meowMEOWmeowMEOW
Re: Holley Mid Rise LS Intake P/N300-126
Same concept as the hi-ram just shorter. Injectors wouldn't have a special part number, as Holley doesn't know what your fuel system requirements would be. iirc they use the standard tall-body injectors like most of the non-truck LS engines, and pretty much every aftermarket company will get you one in any flow you need.
You probably don't see it used much, as I don't really know what gains are to be had. The hi-ram has some gains, but its biggest benefit is cool factor and a love of teaming with some additional atmospheres.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Honestly the only real advantage is aesthetics. The truck manifold is ugly!!! This manifold is trick. It would no doubt be an expensive upgrade, but combined with their coil covers it would seriously help the look of these engines.
meowMEOWmeowMEOW
Heck the high ram should still fit under the hood if your engine isn't too high up on perches, and its barely more expensive. Go big or go home. I would really like to go hi-ram or the ProFlow XT but I'm having a hard time figuring out if I can get one to work with my DBW TB.
I believe Hot Rod or Chevy High performance just did a comparison on that manifold vs stock vs the high rise. I dont remember the outcome except of course the high rise made more power at the top of the rev range.
Trent 12 Cadillac CTS-V 07 Sierra HD 4x4 Duramax 66 C10 Short Wide 63 Chevy II(nova) |
Yeah, as long as the performance is not degraded I am interested in using it purely for the look. Also, the aluminum manifold is surely stronger and less susceptible to cracking. My intent for this thread was to find out if anyone know which injectors will work based on this statement in the installation instruction:
"The 300-121 intake manifold with the 534-204 fuel rail kit is designed to accept Bosch Style EV-1 or Magneti MarelliPico fuel injectors. OE LS fuel injectors may not fit properly in the EFI intake manifold and fuel rail assembly."
#7 | |
meowMEOWmeowMEOW
The only fitment issue would be the height, but that shouldn't be an issue with the injectors I mentioned. The truck injectors won't fit.
Thanks BR3W that's what I was looking for!
