11-12-2013, 03:04 PM | #1 |
Top radiator hose not hot
Well I took my truck for a ride to the store came back wanted to adjust the idle speed a little. Well I touched to top radiator hose it wasn't hot or even warm. I just put a new water pump on in July. It was fine a couple months ago It got hot during warm up now nothing. What could it be????
11-12-2013, 03:20 PM | #2 |
Re: Top radiator hose not hot
How long was the truck running for? If the upper Rad hose is not hot.... The thermostat is not open. So it is either Stuck Shut OR your motor just wasn't warm enough to open
11-12-2013, 03:37 PM | #3 |
It was running for like 20-25 min. Also not sure but just checked coolant level in radiator it's like 6 inches from top..
11-12-2013, 03:48 PM | #4 |
Parts and more parts
There is a chance that you have a leaking head gasket and the water is being pulled into the cylinders. If you go to a radiator shop, there is a test that they can do, to see if you have carbon monoxide in your coolant system. This would tell you if there is a leak. Been there, seen that.
Frank |
11-12-2013, 03:54 PM | #5 |
you don't really want to check the fluid level when it is completely cold but it does sound a bit low. top it off and run it. see what happens.
11-12-2013, 04:09 PM | #6 |
I hope it's not a head gasket. I do notice during startup sometimes there's some white smoke.
11-12-2013, 05:29 PM | #7 |
White smoke means either they elected a new pope or your head gasket(s) are shot.
11-12-2013, 06:06 PM | #8 |
Even if the white smoke is only during startup/warmup not while driving ?
11-12-2013, 08:53 PM | #9 |
Whats the engine temp running at when warmed up?
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
