Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-19-2013, 10:50 AM   #1
MikeS.
MikeS.'s Avatar
63 Burb E brake cable
Hey guys I need the cable that goes from the handle in the cab back to the cables that attach to the brakes.
I bought a truck cable from LMC but it is too short.
Any ideas where I can get the proper cable?
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 11-19-2013, 11:00 AM   #2
notsolo
notsolo's Avatar
Re: 63 Burb E brake cable
Hey Mike whats the length of the cable you need? and are the ends U shaped with a pin. I may have an extra that you can have..(don't get your hopes up its off of a 2wd)....Ed
notsolo is offline   Reply With Quote
Old 11-19-2013, 11:18 AM   #3
MikeS.
MikeS.'s Avatar
It's about 7' long, it does have U shaped ends and a pin.
Past Master
Old 11-19-2013, 11:36 AM   #4
notsolo
notsolo's Avatar
The one I have is 5' long U shaped end in the cab and 2" threaded down under.
Old 11-19-2013, 01:47 PM   #5
MikeS.
MikeS.'s Avatar
Unfortunately it's too short, thanks for the offer though.
Past Master
Old 11-19-2013, 11:21 PM   #6
63burban4x4
63burban4x4's Avatar
Hey Mike, how's the truck coming? I can't help with the cable, but I'm just wondering why the truck & sub are different? I always thought that the truck & sub frames were the same. ie: without the body shell, they are the same? are you sure the length difference isn't between 2wd & 4wd? I could see that. When I got my truck, the e-brake was actually working, and complete, so I never had to replace any parts.
63burban4x4 is offline   Reply With Quote
Old 11-20-2013, 12:05 AM   #7
nbrfd007
nbrfd007's Avatar
Sent my 62 GMC 4x4 Suburban E-Brake cable to inline tube, they built me a new one, fit perfect.
nbrfd007 is offline   Reply With Quote
Old 11-20-2013, 12:42 AM   #8
MikeS.
MikeS.'s Avatar
That could be the difference, I just don't know. I bought a new cable from LMC Truck thinking the truck/Burb would be the same. It was for a 63 2wd though.
Otherwise the truck is coming along nicely. A few small mechanical things, new window rubber except for the windshield, it's already done. Rear tailgate latches for top and bottom. Install seat belts and paint. I'm going to order Vintage Air, tomorrow.
I've been driving it quite a bit, it's a blast to drive.
Past Master
Old 11-20-2013, 01:08 PM   #9
3 On Da Tree
Long bed, short bed, different length in cables?
3 On Da Tree is offline   Reply With Quote
Old 11-21-2013, 03:37 AM   #10
63burban4x4
Mike, The WB for all the suburbans matched the shortbed pickups, but it seems to me the e-brake setup might be different from 2wd to 4wd because of the transfer case. Do they list a 4wd cable at all? Was all the linkage still in place on yours, and not changed from stock? I've seen some cobbled up stuff before.
My truck's still out at Tony's in KC, so I can't measure mine, but our trucks are the same exact thing. You think about asking him about a cable?
He changed the body shell on mine, there was just too much rust to justify the repair of my original body, and he had a nearly rust free one. In the long run it will pay off, but it became a lot more project than I had originally hoped for. Nice to have it down to the bare frame, though, it'll be new from the ground up.
You running that camper yet? -Ed
Old 11-21-2013, 06:56 AM   #11
MikeS.
MikeS.'s Avatar
Hi Ed, good to hear from you. I did send Tony an email yesterday. He showed me your Burb when I visited him in July. I also contacted Inline Tube yesterday, either they'll have one or can make one if Tony doesn't have it.
I took the camper on a couple trips this summer, it's parked for the winter now. The Burb will be too soon. Don't need any road salt on that baby.
Past Master
