11-19-2013, 04:46 PM | #1 |
Cargo Light
My original cargo light was smashed and damaged so i bought a replacement from LMC , it dose not fit tight nor really conform to the body curves and after a couple of year the screws are rusting , any ideas, i thought about getting stainless screws but these have some kind of a shoulder on them
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-19-2013, 05:06 PM | #2 |
Moderator
Re: Cargo Light
Get some stainless screws, the screws in their kit are nothin special. I just installed their cargo light and am very happy with it. I guess I'll swap out the screws for stainless now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-19-2013, 05:49 PM | #3 |
Old member
Re: Cargo Light
Replace with SS screws and take it back apart and put the rubber part in some hot water and let it get soft then install it. I like using my kerosene heater for this. I sit it outside the garage and let it heat up good then place a pan on top to heat up. It works great.
11-19-2013, 06:20 PM | #4 |
Re: Cargo Light
it was about a million degrees in the sun when i did mine. It was a pain in the butt i seem to remember but the warm cab (burning hot) loosened up the rubber. Isnt there a weird tophat nut grommet thing. I put mine in backwards I think and had to redo it all.
11-19-2013, 08:00 PM | #5 | |
Re: Cargo Light
11-19-2013, 08:34 PM | #6 |
Old member
Re: Cargo Light
I didn't.
