Old 11-23-2013, 11:32 AM   #1
Hogger54
Hogger54's Avatar
Todays puzzler. What's it called.
What's the name of the little round clip thingy that holds the parking brake cable on the drum backing plate? I'm looking for the type that has the little prongs that need to be compressed in, to remove the cable on a ford axle.
There must be a specific name, because I've tried searching clamp, retainer, clip, and I can't find them in my catalogs, or online.
Hogger54 is offline   Reply With Quote
Old 11-23-2013, 11:36 AM   #2
semn49
Re: Todays puzzler. What's it called.
Not sure what it's called, but you'll probably have to buy it in a kit I would guess?
semn49 is offline   Reply With Quote
Old 11-23-2013, 11:37 AM   #3
hyatt
as far as i know it is not available seperate Part of cable assembly
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 11-23-2013, 11:47 AM   #4
DransportGarage
DransportGarage's Avatar
Never mind...I re-read your post and determined that I had found the wrong clip. Ford, huh? Can you post a pic of where it goes?
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-23-2013, 12:11 PM   #5
NEWFISHER
NEWFISHER's Avatar
Jesus clip
NEWFISHER is offline   Reply With Quote
Old 11-23-2013, 12:12 PM   #6
Hogger54
Hogger54's Avatar
Ya, it's a ford 8"
Old 11-23-2013, 12:39 PM   #7
Hogger54
Hogger54's Avatar
Stupid photobucket it's showing the edited photo. It's the round clip piece on the small horizontal spring that looks kind of like a badminton birdie.
Old 11-23-2013, 01:06 PM   #8
Daze57
Daze57's Avatar
i dont think there is a specific name for that tension clip you are refering too . although the best way to get it released in to use a very small hose clamp - put it at the back of the tension fingers and tighten it up - fingers will compress enough to slide it out a little and release
Daze57 is offline   Reply With Quote
Old 11-23-2013, 02:37 PM   #9
DransportGarage
Ya, it's a ford 8"
This one is on the crimped cable assembly and is not meant to be taken off of the cable. Contact "The Right Stuff" (getdiscbrakes.com), or your favorite supplier for a new CABLE. If you're really lucky they might sell you just the retainer, but I don't know how you're going to disassemble/re-assemble the cable.
Bob
Old 11-23-2013, 02:43 PM   #10
mr48chev
mr48chev's Avatar
As Daze57 and Bob aka Drainsportgarage said it doesn't come off and as Daze57 suggested the simple way to take it off is use a small hose clamp and squeeze the ends in so they slip through the hole in the backing plate. I don't know of any replacement for that end and don't know if you could salvage one off another cable and put it on yours if yours is damaged.
My ongoing truck projects:
Old 11-23-2013, 03:01 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
The release tool for it is LISLE 40750 it is part of the cable and can't be purchased separately.
dwcsr is offline   Reply With Quote
Old 11-23-2013, 04:23 PM   #12
G&R's57GMC
G&R's57GMC's Avatar
Or you could slip a 12 point wrench over it and rotate the wrench up and down while pulling the cable housing out of the backing plate.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-23-2013, 04:28 PM   #13
Hogger54
Hogger54's Avatar
Boo. The guy I got the rear end from, cut the cables about a foot in front of the drums. I was hoping to fab up a custom cable set up because I'm planning on changing my parking brake pedal to a lever.
Oh well, I guess I'll have to get replacement cables and go from there.
Thanks for all the help!
Old 11-23-2013, 04:30 PM   #14
Russell Ashley
Russell Ashley's Avatar
Classic Tube (www.classictube.com) makes cables so they would have those clips. I don't know how you would get the old one off though, as the cable ends aren't removable.
Russell Ashley is offline   Reply With Quote
Old 11-23-2013, 04:42 PM   #15
DransportGarage
Well, that would be a game-changer if you're able to fab a cable. You should be able to find an old cable with that retainer in the junkyard. Just cut it up and you've got your part.
Conversely, '69 Nova rear cables run $25 each at The Right Stuff (Columbus, Ohio). If you told them the total length of the cable and sheave and the type of rear end I'm sure they could make a couple for you in about that price range. (Actually, you might be able to tell them the year of the truck and rear end type and they'd be able to figure it out.)
Bob
Old 11-23-2013, 06:46 PM   #16
Hogger54
Hogger54's Avatar
Ooh, I need to look into that. Thanks.
Old 11-23-2013, 11:10 PM   #17
wahl4m
PARK CABLE REMOVER TOOL,go buy the lisle tool or take 1 or 2 of them tiny give -away slotted screw drivers -bend one a little in the middle of the driver-slip it between the backing plate and cable -pry the outward clips inward and partially pry the cable towards the front of the vehicle-when it moves partially push in on the outward side clips and it should be somewhat out /so the clips are in the hole /so the cable will come out ? good luck mike
wahl4m is offline   Reply With Quote
Old 11-24-2013, 01:01 AM   #18
1project2many
I've been using a cheap set of flare nut wrenches to compress those spring clips for years. Tap the wrench down over the end of the clip and presto! They're compressed. And it gives you some leverage to move the cable if needed as you pull it out of the backing plate.
1project2many is offline   Reply With Quote
Old 11-24-2013, 01:03 AM   #19
solidaxel
solidaxel's Avatar
I have had good luck with Industrial Cables Inc for all custom to stock cables
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-24-2013, 10:02 AM   #20
Russell Ashley
If you are changing your whole parking brake setup you should give Control Cables a call or go to their website. They can make the cables to your measurements.
Old 11-24-2013, 05:09 PM   #21
solidaxel
solidaxel's Avatar
Yes it is Control Cables !
Industrial Chassis Inc, I used them both and I am "much" older and it is easy to confuse me !!!
LS 3 4L70E
Old 11-24-2013, 05:26 PM   #22
Russell Ashley
LOL, solidaxle, but I doubt you are "much" older than me. I was born four months before WW2 started so that definitely puts me in the "Senior Citizen" range.
I can identify with the easy to confuse part, though.
Old 11-24-2013, 06:40 PM   #23
dwcsr
Hollister Road Co.
dwcsr's Avatar
I saw industrial cable and read it as control cable....but I'm old people to...
Old 11-24-2013, 07:33 PM   #24
solidaxel
solidaxel's Avatar
Thank You, I knew you would understand !!!
LS 3 4L70E
