steering shimmy
Hey guys, 2000 Silverado. 265-75-16 Kelly safari TSR tires
at around 30 - 35mph only, my steering wheel slightly shimmies left and right. it doesn't do it below 30, and also doesn't do it on the highway. I asked the oil change shop to rotate the tires, but he said I just rotated them recently and the problem sounds more like an alignment or tie rod issue. any have this happen? any opinions?
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
Re: steering shimmy
the steering rack ends wear out. They are replaceable. I just replaced these and the tie rod ends on my 2002 1500. Jack a front wheel up, grab the tire and rock it back and forth. If there is any play,then they are worn.
Jeff
Jeff 1986 Chevy C10 Custom Deluxe swb 1983 Chevy Silverado swb stepside, factory 6.2/700r4 2002 GMC Sierra SLT 1979 GMC Jimmy High Sierra 1978 Chevy C10 Big 10 lwb Scottsdale |
Re: steering shimmy
the front end links the pitman arm idle arm ball joints and wheel bearings all wear out really quick. id check all that.
Re: steering shimmy
Lucky me , rotating the tires fixed the problem
| Bookmarks |
