Old 12-03-2013, 04:58 PM   #1
FrankieD
FrankieD's Avatar
How do I adjust the Shift Indicator
i just bought a 94 K2500 with a 3" body lift and the shift indicator is off, they welded a extension ti the linkage but it is way off is there some way to fix this or do I have to live with it..
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 12-05-2013, 02:52 AM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: How do I adjust the Shift Indicator
Count the clicks!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 12-05-2013, 03:48 AM   #3
andrewmp6
Depends which way its off you have to adjust or make your own linkage,Or lose the body kit and put a stock linkage back on it.
andrewmp6 is offline   Reply With Quote
Old 12-05-2013, 02:38 PM   #4
OrrieG
OrrieG's Avatar
If it is a mechanical rod the fix would be to put the trans in neutral, shifter at neutral and see how much longer or shorted it needs to be. Add or shorten enough to tread the rod for a threaded rod end, maybe using a heavy turn buckle with reverse threads so turning oneway lengthens, other shortens.
OrrieG is offline   Reply With Quote
Old 12-05-2013, 03:02 PM   #5
FrankieD
FrankieD's Avatar
Ok thank guys I will try something and see what happens I don't like driving with the needle on N not sure when I will get to it, it will be in the 20's trough the weekend.
Old 12-05-2013, 07:08 PM   #6
LONGHAIR
Surely there is some adjustment built into it?
I have put dozens of bodylifts on earlier model trucks and everything with a solid linkage rod had a sliding adjuster on the transmission end.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-06-2013, 09:22 PM   #7
FrankieD
FrankieD's Avatar
OK I messed with it tonight and set it to Netural like OrrieG said, so R,N & D were right on but P I had push so it would click and it would only go to 2 so I am thinking the bend needs to be straightened out to give it more throw
