Old 12-10-2013, 02:24 PM   #1
csdineley
csdineley's Avatar
Replaced intake gaskets now ticking/knocking?? Help
Hello
I've been trying to locate the source of a ticking or knocking (not sure which). The truck was running pretty good before this, but had a slight intake leak. So I thought I'd change them out. Used felpro 1205 gaskets and rtv black for china walls. After I got it back together the noise appeared. I looked for another leak haven't found one. Using a stethoscope the noise seems to be everywhere. But for some reason I think it's cam related? Tried to adjust valves but didn't help. Pulling each spark plug wire one at a time doesn't change the noise. It increases with rpm's.
Stock 87 350 originally tbi converted to q-jet.
Uploading a video to youtube right now. Once it's done I'll post it.
csdineley is offline   Reply With Quote
Old 12-10-2013, 02:52 PM   #2
csdineley
csdineley's Avatar
Re: Replaced intake gaskets now ticking/knocking?? Help
http://youtu.be/zzri0_EhtsU
Old 12-10-2013, 03:10 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
That's one hell of a noise. What's the oil press looking like?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-10-2013, 03:20 PM   #4
brakenit
Did you change/check the oil after you were done?
brakenit is offline   Reply With Quote
Old 12-10-2013, 03:21 PM   #5
csdineley
csdineley's Avatar
45ish (mark between 30 and 60), Cold. I haven't let it run for a few minutes at a time, because of the noise.
Old 12-10-2013, 03:23 PM   #6
csdineley
csdineley's Avatar
yes I did a oil and filter change
Old 12-10-2013, 03:39 PM   #7
mrolds88
Couple of thoughts. First is did the distributor get phased into the oil pump correctly? And second, did anything drop into the intake valley while intake was getting put back on?.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-10-2013, 03:57 PM   #8
csdineley
csdineley's Avatar
"Did the distributor get phased into the oil pump correctly?" Don't know how do I check that?
The oil pump shaft sounded like it came up a little when I first pulled the distributor, but fell back into place.
I tripled checked for anything in the valley before putting intake back on.
Old 12-10-2013, 04:04 PM   #9
INSIDIOUS '86
Did you pull the plugs off the distributor? You may have one that's out of sequence. That can make a racket as well
Old 12-10-2013, 04:13 PM   #10
Shugalou
Shugalou's Avatar
I had a similar issue when working on my BMW V8, different motor I know but I ended up taking everything apart when I heard the noise because I was scared something fell in.
Didn't find anything put it all back together and it still made the sound.
Reved it up a few times and the sound went away something was ticking in the valvetrain due to lack of lubrication.
Can't watch the vid at work to see if you have tried this already
Shugalou is offline   Reply With Quote
Old 12-10-2013, 04:37 PM   #11
Jake Wade
Jake Wade's Avatar
Wow! That is loud. Get a piece of hose and hold to your ear while probing around. Start around the oil pan.
Jake Wade is offline   Reply With Quote
Old 12-10-2013, 04:40 PM   #12
Jake Wade
Jake Wade's Avatar
Sounds in the bottom end, anything valvetrain related would be half the speed.
Old 12-10-2013, 05:52 PM   #13
geezer#99
geezer#99's Avatar
You might have one of the intake bolts in the wrong hole. If you put a longer one in where a short one belongs you can have the end of the bolt binding on a pushrod.
Old 12-10-2013, 07:44 PM   #14
cadillac_al
I don't see how that loud noise is going to come out of it. It sounds like a metallic tap to me. Whatever it is , is getting damaged. I would take it apart again and do it over (and swear the whole time). Hopefully it will be obvious when you get it apart. I was thinking a valve issue at first but I don't hear it out the tailpipe. It does seem to be in the lower half of the engine. Maybe the dist/oil pump as someone already mentioned.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-10-2013, 09:08 PM   #15
savatreatabvr
savatreatabvr's Avatar
Originally Posted by jake wade View Post
sounds in the bottom end, anything valvetrain related would be half the speed.
good point!!!
savatreatabvr is offline   Reply With Quote
Old 12-11-2013, 12:03 AM   #16
csdineley
csdineley's Avatar
Ok first thing in the morning I'll pull the intake. Should I also pull the oil pan or should I just wait?
Old 12-11-2013, 12:34 AM   #17
mrolds88
When you look at the bottom of the distributor shaft there is a piece that looks like a flat screwdriver tip that interlocks into the slot in the intermediate shaft the drives the pump. If you don't get the piece on the distributor down in the slot you put pressure on the bottom of the oil pump and it will cause failure. Also check and make sure that the intermediate shaft went back into the right spot on the oil pump.
93 K2500 xcab 6.5TD
Old 12-11-2013, 11:31 AM   #18
csdineley
csdineley's Avatar
Well I've pulled the intake and drained the oil this morning. I don't see anything out of the normal,yet. Guess I'll try the pan next.
Old 12-11-2013, 12:10 PM   #19
cadillac_al
Does the bottom of the distributor look normal? Do all the rocker arms move normally? Does the oil pump turn smoothly? That's a bummer that something in the bottom end picked this time to fail.
I spun a rod bearing once during an intake/cam change. I blamed it on contaminating the oil during the swap but the engine didn't start knocking right away. It probably took 50-100 miles before it sounded a lot like yours. That's why it's hard for me to believe that you spun a bearing so quickly on start up. Good luck.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 12-11-2013, 02:11 PM   #20
csdineley
csdineley's Avatar
Oil pan removed.Ran a magnet through oil. No clucks of metal or anything that I could see. Not sure what I should be looking for now??? Last time I put a motor together was 20 years ago.
Old 12-11-2013, 02:57 PM   #21
mickeykreg
mickeykreg's Avatar
x2 on this.
just curious...did you find any intake bolt to push rod interference when you took it apart?
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 12-11-2013, 03:25 PM   #22
csdineley
csdineley's Avatar
mickeykreg I did check the distances, and it doesn't look like that was the problem.
One thing I did find, was the little plastic piece that the oil pump shaft goes into is broke. Not sure if that would cause all that noise, but that's something.
Old 12-11-2013, 04:06 PM   #23
mrolds88
That might be the winner. Well sort of. Maybe the oil pump drive shaft was off center and hitting the pump body. Sounds like you need a new plastic collar.
93 K2500 xcab 6.5TD
Old 12-11-2013, 05:26 PM   #24
Jake Wade
Jake Wade's Avatar
Give all the connecting rods a shake where they go around the crank journal while you have the pan off.
Have a friend turn the engine back and forth(by hand) while observing the rods on the journals.
Old 12-11-2013, 05:44 PM   #25
csdineley
csdineley's Avatar
okay, as I was picking up my stuff for the day. I found a head of a bolt or something in the oil pan. Any clue where this came from.
