Old 12-15-2013, 11:07 PM   #1
blue57
blue57's Avatar
55-59 seat options
I am not sure if there is already a thread like this, but i was wondering what seats guys or gals are running in there pickups? Trying to give my dad some options. I have a bench seat from a 1990 chevy p/u in mine. I have seen a set of low back Honda buckets in another. Thanks for any input
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 12-16-2013, 09:37 AM   #2
59stepside
59stepside's Avatar
Re: 55-59 seat options
I was keeping my own running list as I saw them on here. Don't have it with me right now, but I got most of them from the interior thread. I think this could end up being a fantastic reference if done right!
Maybe a picture(s) of the seat
Width of seat
What the seat came from
And year of truck it is in.
Just an idea....
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 12-16-2013, 05:41 PM   #3
OrrieG
OrrieG's Avatar
Please do a deep search using the "67-72..." option in the box in the header above. It should pick up some pretty detail threads about what seat fits in a TF. Here are 07 Yukon third row seats in mine, the build thread has details on how and why.
OrrieG is offline   Reply With Quote
Old 12-16-2013, 07:23 PM   #4
fabguy
Elev8r Man
fabguy's Avatar
I am running the same seat as you with one possible exception. I cut a few inches out of the bottom bracket and welded an angle to it to be able to attach to the floor. It sounds crazy but I still have descent leg room.
I wanted to sit low when I am driving, I am 6' tall BTW.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 12-16-2013, 08:56 PM   #5
OrrieG
OrrieG's Avatar
I'm 5'6 and set the height based on the steering wheel and where my elbox fell on the window sill. 4x4 plus 2x4 plus 1" steel did it (6"). So 5'6 + 6" = 6 feet!
Old 12-17-2013, 08:25 PM   #6
_Ogre
_Ogre's Avatar
i used 6'' chopped and modified 07 ford fusion seats
i made pedestals to raise them up to give me leg room using the same wood method as orrieg
and then finished off the pedestals
@fabguy: you are 6 feet short. (as the shortest male in my family i know all the short jokes )
@orrieg: you are the inverse of me. you 5'6'', me 6'5''
shop air compressor timer
Old 12-20-2013, 02:41 PM   #7
tpimuncie
tpimuncie's Avatar
What bench will fit that doesn't go above the window? (big window)
tpimuncie is offline   Reply With Quote
Old 12-20-2013, 05:14 PM   #8
OrrieG
OrrieG's Avatar
Here is a shot of mine from the back, the headrest and extension for the three point belt sticks up a little. Center person does not get a headrest. I have my seat a little higher than average since I am vertically challenged. I wanted the three point belts, as a youth I had the opportunity to bounce off a solid steering wheel at 30 mph and get a whiplash without belts and in made both a physical and mental impression.
Old 12-20-2013, 06:48 PM   #9
fabguy
Elev8r Man
fabguy's Avatar
Lol, I like it.
Although when I put my arm on window will my elbow is up around top of my shoulder.
Oil, when my kids ride with me they have to stretch a lil bit too look out the window.
1939 2 door sedan
Old 12-22-2013, 12:32 AM   #10
_Ogre
_Ogre's Avatar
i need to take a picture of my headrests, 3x6x.25 hard foam covered in the same fabric as my seats.
double sided taped over my rear window to the back of the cab, no way my head could ever hit the back window
Old 12-25-2013, 03:28 PM   #11
hotrodsbyray
OrrieG - how comfortable are those seats now that you've had them a while?
Reason I ask is that i am a fairly big guy at 215 and didn't know if GM used thinner springs or foam since they're 3rd row. I know I need to find a truck with them and try them out but was just wondering what you thought.
hotrodsbyray is offline   Reply With Quote
Old 12-25-2013, 04:07 PM   #12
OrrieG
OrrieG's Avatar
Not on the road yet, but cannot be worse than the stock one that had 2x4s for support. They seem to have pretty dense memory foam, which is what my back likes, similar to our Honda in firmness. If I want or need something cushy down the line, its an easy fix.
Old 12-25-2013, 05:17 PM   #13
Clarance J
Clarance J's Avatar
Hello all, Another option might be an older seat. Its in a TF 55. It's 53 inches wide and with the 1 inch spacer that levels out the floor plus the electric set up it ends up about 12'' off the floor. Seat is out of a 79 Cadillac. I took off the head rests because they took up too much space in the rear window. You can only see about an inch of the seatback from the back. Very comfortable.
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 12-25-2013, 11:33 PM   #14
Spblack
Spblack's Avatar
I just picked up a bench seat out of an 87 suburban. it fits almost perfect. ill post pictures tomorrow.
Spblack is offline   Reply With Quote
Old 12-25-2013, 11:40 PM   #15
Spblack
Spblack's Avatar
here you go. im going to make a hinge for it to move forward if I need to get behind it
Old 12-25-2013, 11:41 PM   #16
tpimuncie
tpimuncie's Avatar
Sounds interesting thanks
Old 12-25-2013, 11:44 PM   #17
Spblack
Spblack's Avatar
couldn't pass up the deal. it was only 50 bucks off craigslist.
Old 12-25-2013, 11:46 PM   #18
tpimuncie
tpimuncie's Avatar
Yes sir, i want a bench as well but dont like it going above glass not sure what my options are yet.
Old 12-26-2013, 10:01 AM   #19
fabguy
Elev8r Man
fabguy's Avatar
Here is a pic from my build thread. The seat only has a seat cover for now. As you can see it won't come above the bottom of the window.
Yes you do sit a little low, but that is what I wanted for mine. If you were closer I would say to stop on by to try it out. lol
1939 2 door sedan
Old 12-26-2013, 01:38 PM   #20
poncho_villa
poncho_villa's Avatar
Here is a link to an old thread on this same topic.....
http://www.67-72chevytrucks.com/vboa...d.php?t=577559
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 12-26-2013, 02:39 PM   #21
Speedbumpauto
Speedbumpauto's Avatar
I did buckets out of a 99 Silverado with a console from a late 90's Windstar van. The bracket mods were pretty simple + the headrests were removed before upholstery as well as the arm rests for more symmetry.(upholstery guy is OCD) The seat back stops just below the window but don't have a pic of that angle.
Speedbumpauto is offline   Reply With Quote
Old 12-26-2013, 02:54 PM   #22
The Haberdasher
Speedbump, luv the buckets. Question, i noticed you fabricated your brackets to slope just before the hump/railing for original setup. Does that make it easier to move seats back and forth? If you catch what im asking. Thanks in advance
The Haberdasher is offline   Reply With Quote
Old 12-26-2013, 04:29 PM   #23
Speedbumpauto
I can't say for sure since it's not on the road. I just sat in it and the driver seat is power, but it works well. Anyway, it wasn't the intent. There were existing holes in/on the front ridge that I assumed were for the seat,(was bare metal when I got it) and holes in front of the rear ridge that I thought the same about so I made the brackets to fit those holes and tested it a couple of times during fabrication for comfort and visibility. I'm a 5'11" 200 pound guy and I fit OK. I'd like a little more leg room but I'll trade it for the comfort of those seats+ I mounted them some lower than many because I chopped the top 3 inches. I still have plenty of head room.
Old 12-27-2013, 12:18 AM   #24
The Haberdasher
Appreciate the reply Speedbump.
Old 12-27-2013, 04:10 AM   #25
tpimuncie
tpimuncie's Avatar
Looks good, whats it from?
