C10 addict
Two 1967 Dash harnesses for gauges and a/c
I have a pair of 67 dash harnesses out of Arizona trucks. I was going to make one good harness out of both because one has been cut a lot and the other I had to cut the plastic at the firewall to get it out. It's a bit of work but it will save you a good amount of money over the cost of a new one. $25 shipped for the pair
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 12-30-2013 at 04:43 PM. |
C10 addict
Re: Two 1967 Dash harnesses for gauges and a/c
Let's try $30 for both, good parts to repair a damaged one as well. These are the same harnesses for 1968 as well
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 12-23-2013 at 11:23 AM. |
C10 addict
Here are a few pictures of the better harness, no connectors have been cut off. The ignition connector will need to be replaced because the clips broke off. This is the one that I had to cut at the firewall.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
C10 addict
bump
C10 addict
ttt
Can I get a picture of what you had to cut to remove this harness? And also is this a 67 specific harness. I will take it if it isn't sawed off at the main bulk head meaning from outside to inside. I would hate to have to pull every wire out to re-install them into another good fuse block..I guess a better way to describe is I'm looking for the inside main under dash harness not cut up or ruined on the side that goes though to the firewall. I can replace the ignition part of the harness easy enough...
Thanks and Merry Christmas. Kev.
Kev's-C-10 ![]() |
C10 addict
The last picture in post #3 shows where it was cut, which was at the bulkhead. The bolt that holds the engine harness to the dash harness at the firewall stripped out so I had to cut through it.
C10 addict
I'd hate to recycle these for the copper if someone can use them, how about $25 shipped? That will cover shipping and gas to drop off the box.
C10 addict
ttt
![]() Join Date: Dec 2013
$20.00 shipped ? to 37918
C10 addict
$25 shipped is as low as I can go
C10 addict
Bump
#13 |
![]() Join Date: Apr 2013
You wore me down. I'll take 'me for $25 shipped. Let me know how you want payment.
#14 |
C10 addict
PM sent
