Old 01-01-2014, 12:58 PM   #1
stepsider
stepsider's Avatar
Alternator/ AC question
I have a 68 chevy P/U. I was told that I have a 81-84 350 engine, My alternator is on the Pass. side. Is the AC compressor on the drivers side. Looking for info, Thanks
stepsider is offline   Reply With Quote
Old 01-01-2014, 01:02 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Alternator/ AC question
AC is on the drivers side of my 83
Malo83 is offline   Reply With Quote
Old 01-01-2014, 04:59 PM   #3
wilkin250r
wilkin250r's Avatar
I'm mostly an electrical man, not so much a motor man, but I think all the accessories can be swapped to their original locations. So an 81 motor may still have 1968 brackets and accessory locations. And the motor year certainly hasn't changed your AC condensor location, so you're going to need the proper hoses to connect to that.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-02-2014, 09:50 AM   #4
Rich84
Rich84's Avatar
So it is possible to to use the older brackets to switch the location of the alternator and the a/c??
I have a TPI set up and I hate the look of the a/c hoses going over it..I'd rather not go with the serpentine setup if I don't have to.
Rich84 is offline   Reply With Quote
Old 01-02-2014, 10:44 AM   #5
stepsider
stepsider's Avatar
My 68 alternator has the serpentine bell but the power steering has the single belt set up. I will check out some of the car shows this coming year to see their set up. I'm having trouble finding drivers side set up,long water pump & headers. Good thing that I have about 5 months to work with. I'm with you, don't like the hoses going over.
Old 01-02-2014, 10:49 AM   #6
Rich84
Rich84's Avatar
I saw a bracket to mount the a/c down low on the drivers side..It uses the fuel pump location as a mounting point.
Old 01-02-2014, 11:07 AM   #7
xole
xole's Avatar
Give Alan Grove Components a call. All they do is accessory brackets.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
