Old 01-15-2014, 11:50 AM   #1
chris989
power window upgrades
Hello all,
I have been searching for possible options for my power windows.
My issues are, there are still slow even after new motors and a complete overhaul.
My vent windows always whistle some.
And my switches, through stock, are uncomfortable compared to newer trucks.
Has anyone converter to a one piece window, or found a motor that is better than another? I would love to hear if anyone has modified their panels to accommodate a newer style switch??
Thank you,
Chris
chris989 is offline   Reply With Quote
Old 01-16-2014, 01:25 AM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: power window upgrades
One piece windows can whistle worse (if you pooch the install), seach the site for some builds that did the swap.
search eBay and google for different switches, lots to choose from out there, most common I've seen are a chrome switch with an over/under button to run the windows. Only different is the switches will be two separate units (unlike the stock driver's door switch that has two switches in one unit) so most people mount then in the console between the front two seats (you'll see what I mean if you seach some images on google)
If you replaced your window felts/channels/rubber seals your window will be slow until they are broken in
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-16-2014, 02:08 AM   #3
wilkin250r
wilkin250r's Avatar
I've heard of people replacing the wiring, and using the switches to control relays. The theory is that the stock wiring and switch robs too much power from the overall circuit. Replacing the wiring and using relays allows full voltage to the motor and significantly increases the motor speed.
I've never done it, but my background is in electrical engineering, and I can tell you the theory makes perfect sense.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-16-2014, 07:42 PM   #4
meatwagon83
meatwagon83's Avatar
from what i have heard the relays make the windows into upside-down guillotines! i cant wait to do it to mine!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 01-16-2014, 08:48 PM   #5
rs74
rs74's Avatar
I was thinking there was a thread on how to do the relays somewhere.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-16-2014, 08:57 PM   #6
mrolds88
http://67-72chevytrucks.com/vboard/s...+window+relays
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-18-2014, 03:57 PM   #7
nekkidhillbilly
relays are good idea pretty easy too.
nekkidhillbilly is offline   Reply With Quote
Old 01-19-2014, 09:58 AM   #8
homemade87
I did the relay mod. Pretty simple. It was a diffrence of daylight and dark. I believe they are faster that my new truck. What happens with these trucks is the power has to go around the world before it gets to the window motor. It may only be running from 8 to 10 volts at the motor. The relays bring straight battery power to the motors. I used # 10ga wire to relays and motors to keep the line loss down as much as possible. Worked great for me. It is definetly worth the time and trouble.
homemade87 is offline   Reply With Quote
Old 01-19-2014, 05:04 PM   #9
bnoon
While you're doing it, add express down to it. Then you don't have to touch the switches for so long either.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-19-2014, 05:21 PM   #10
homemade87
How did you do the express down to it. I would like to do that. Part # of what you used
Old 01-20-2014, 01:31 AM   #11
andrewmp6
Autoloc makes a one touch up and or down add on http://www.autoloc.com/catalog/Power...-Express-Units
andrewmp6 is offline   Reply With Quote
Old 01-20-2014, 08:54 AM   #12
homemade87
Thanks for the link. This would be a great addition to my truck. I have a lot of modurn features like automatic door locks at start up , compass/temp auto dark rear view mirror , remote door locks with timed interior light, security , electronic cruise with my ls motor , also have tailgate security with tonneau cover , and home link in overhead console for garage door.
Chris, You could do this mod for for not much money. There is several threads that will help . It would be worth your time. Good luck
Old 01-20-2014, 02:03 PM   #13
nekkidhillbilly
the one touch thing never mattered that much to me
Old 01-20-2014, 06:36 PM   #14
SilverMiner
SilverMiner's Avatar
Has anyone ever tried the relay upgrade with a power rear window like in a suburban or K5? I'd imagine that if there is enough voltage drop just getting to the door windows of a pickup to be noticable, the drop all the way to the rear of a suburban must really be significant.
I'm close to diving into the tailgate of my 80 Suburban once the weather gets just a bit warmer. The wiring is probably similar enough that I think I'll give the relay project a try.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
