Old 01-20-2014, 04:39 PM   #1
steelhorse
steelhorse's Avatar
6 Cyl Help
I have a customer that brought in an 81 C10 with a 250 6 cyl that was just rebuilt and he wants me to get it running. The problem is all the emission stuff is in the passenger floorboard and I could use some pics on where everything goes. There was also a little bag with 2 brass tubes that look like inserts to something. Anyone have an idea where they go? I will post pics as soon as I can.
steelhorse is offline   Reply With Quote
Old 01-20-2014, 09:14 PM   #2
bluebulletk10
Re: 6 Cyl Help
You can run without the emission stuff, the humps on the valve cover are held on with some weak spot welds that can easily be broken, when the humps are removed you are left with two open holes one for a breather another for a pcv ad the with the lines going to the block from the valve cover you can cut the thin metal off at the bolt and weld it closed and you will end up with a pretty sharp looking engine we did it one mine and it worked great
bluebulletk10 is offline   Reply With Quote
Old 01-22-2014, 05:59 PM   #3
steelhorse
steelhorse's Avatar
Re: 6 Cyl Help
The customer want it back stock. I figured out the air tubes but am possibly missing the parts for the pcv. Anybody have any pics with the air cleaner off?
Old 01-22-2014, 06:47 PM   #4
bluebulletk10
Re: 6 Cyl Help
What parts do you think your missing?
Old 01-23-2014, 07:32 AM   #5
D13
D13's Avatar
Re: 6 Cyl Help
Hope this works. And BTW there's a difference depending on year or 3/4 ton. This is not my truck, found this somewhere, but it's similar. Note the PCV valve in the top, the steel lines into the risers, and the wild goofy double line set up on the passenger side.
If you depserately need more pics I can go try to get some of my 81. Don't rmeember if the motro swap kept all the emissions stuff, think it did, IIRC it's stil the 2bbl carb. Also have an 84 that I think is stil complete. Understand these are in a 4' snow drift and it's 5 degress out.... so my enthusiasm is somewhat lacking.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-23-2014, 11:44 AM   #6
71maligreen
Re: 6 Cyl Help
they look and run better without all that crap!!!
71maligreen is offline   Reply With Quote
Old 01-23-2014, 06:42 PM   #7
bluebulletk10
Re: 6 Cyl Help
Yeah it's not good to pump all that crap back into the motor
Old 01-24-2014, 10:49 AM   #8
steelhorse
steelhorse's Avatar
Re: 6 Cyl Help
I agree but the customer wants what the customer wants. I have the four air tubes in place but that leave one hole in the head near the carb and I have no idea what goes there. Some parts are missing. He had someone else start the job then it was towed here for me to straighten out.
