5 year builds "Done"!!!!
Owned this truck in 1974... found it and bought (what was left of ) it in 2009. 5 years of restoration and it's done.....
Re: 5 year builds "Done"!!!!
Pic 2
Pic 3
Pic 4
Pic 5
Pic 5
Looks good, nice and stock, necks a lil sore though.
Nice job!
GOD BLESS AMERICA! |
![]() Join Date: Sep 2006
Here maybe this will help your neck...
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
One more.. and nice truck by the way...
Sweet job on the build...!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
beautiful truck excellent detail!!
#13 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That is a very nice restoration
#14 |
Beautiful, man, just beautiful!
#15 |
Very nice job, power drums or did you swap the fronts for disks?
Tell us a little bit about it!
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear 1966 C10 Fleetside 350 W/ Saginaw 4 speed 1985 K10 Chevy 6.2 diesel 700r4 longbed 2001 Dodge 3500 Dually 24v NV5600 4x4 USMC Reserves Jason |
#16 |
64-66 CHEVY JUNKIE
X2. Very Nice Indeed!!!! GC66.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
#17 |
I'm running stock brakes and added the factory booster. it stops on a dime.The engine is a 1977 305 motor I had in a donor truck. I wanted to clone the motor as much as possible to a Stock 283. I added (modified) stock manifolds, valve covers, brackets and put a canister oil filter on it. I drilled the side of the passenger side valve cover and added a baffled nipple fitting from Jegs. I placed a stock 1966 pcv valve into an elbow coming out of the manifold and connected the two. The motor breathes fine. I wanted a stock appearance battery and added a tar top battery cover to a black pep boys battery. I stripped the battery decals and replaced them with a period correct delco decal. In addition the formerly "polished aluminum radiator was roughed up and painted the proper black...Although not 100% stock it's a nod towards being original and was a lot of fun to build
#18 |
Below the air cleaner snorkel you can see the valve cover baffled nipple. I have since painted it grey and satin black as a camouflage. In my opinion this is the best way to retrofit scripted valve covers for connection to a pcv. (It' so much easier to put the baffled nipple into the cover and add the threaded pcv valve to the manifold)...
#19 |
Looks like a job well done! Thanks for the pictures!
#20 |
I was going to ask if that was a 283 or not, the intake manifold looked like it came off a 283. Ram horn exhaust looks good painted up, hell the whole engine compartment looks good.
You going to drive this thing often or just take it to car shows?
#21 |
Very well done, cool ride.
#22 |
Well done. Got before pics?
#23 |
![]() Join Date: Nov 2001
That truck would be perfect if it was not for the finger prints on the ignition key. Very nice truck , very good work you do. Nick
#24 |
A spirit with a vision is a dream with a mission - Neil Peart RUSH |
#25 |
very good looking truck glad you kept it original
