oil pressure help
at idle my oil pressure gauge shows around 10 to 20 and fluctuates back and forth at times. when i am running down the highway it is pegged at 60. what would be causing this oil prssure switch, gauge going bad or oil pump?
Rodney 1974 Chevy Big 10 1983 GMC Sierra Classic 1500 1986 Chevy K20 2013 Dodge Challenger 2014 GMC Sierra |
Re: oil pressure help
I would install a mechanical gauge to verify your readings.
Let me know what you find out. i'm am also seeing my oil pressure spike but even at idle. Oil level is fine.
i havent had time to mess with it since my post. i am going to dig into it this weekend or next. as soon as i figure it out i will let you now.
I appreciate it. I am having issues with my 87 r10 choking when the throttle is punched. I don't think it is related to the oil pressure but would still like to know why it is reading so high.
Sounds fine to me, my rebuilt 383 gets about 20 at idle hot and 60 at speed.
Typical small block chev.
![]() 1985 C10 2004 Avalanche |
at idle the gauge needle fluctuates and doesnt stay at a constant pressure according to the gauge needle. at idle it will bounce back and forth from 10 to 20 and on the highway sometimes it shows anywhere between 30 to 60.
prior to this starting to this happening idle pressure at around 20 and highway at 60 with no fluctuation of the needle. i am hoping it is the oil pressure sender that just needs to be replaced.
is yours fuel injected?
all original 86 carbureted
| Bookmarks |
