Frame bent? Or is this normal?
Re: Frame bent? Or is this normal?
It is normal
x2. It's for oil filter clearance with an inline six.
Like the others said. That's normal. Here's my 1965 C10 frame. Looks the same as yours.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
![]() Join Date: Oct 2012
My frame (1965) is the same....plenty of room for the 1/2 quart spin on and just enough room for the longer 1qt spin on.
I knew it was normal, but I didn't know why it was that done that way. Good info.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
It lines up with the oil filter for the L6 engines. The older style filters were longer I guess.
normal normal normal... is going to work great for AC clearance maybe too...
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
also provides additional clearance around the fuel pump on V-8's
hillbilly
That does look good for the a/c compressor. Which mounts are you using?
-1962 C-10 |
#11 | |
hillbilly
Is that stock location or ? Forward or back?
-1962 C-10 |
#13 |
#14 |
Thanks for the info all. Good to know it's normal!
#15 |
![]() Join Date: Mar 2013
Yep! Its normal!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#16 |
Think again... Not enough room on my 6.0 and not worth cutting on the frame.
#17 | |
Wisconsin.... A/C = 2 or 3 weeks of the year it is really even useful.
| Bookmarks |
