![]() Join Date: Sep 2005
temp sensor
what are yal doing for a tempo sensor tring to get stock guages hooke dup till i get the money for dokota digital guages i'd like to not have to drill the head on teh passager side as the engine is in the truck already.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Fabricate till you "puke"
Re: temp sensor
You wont run the stock guage,without drilling to fit? I opted for an Auto meter 90 sweep elct guage & the adaptor /sensor to fit the app. longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: temp sensor
There is an adapter/sender setup I and many others have used. Do a search on my posts and you'll find it.
No drilling, both the adapter and sender are auto meter parts. |
![]() Join Date: Jun 2012
Re: temp sensor
I drilled and tapped my water pump and put the sensor there.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
Re: temp sensor
My opinion, does not really make a diff on your truck....but I will lay my thoughts down? Think about what you are playing, also where you want to go
Old member
Mine is installed on the back passenger side of the block. I had a long senor and a short bushing that was right for the block threads.You can see the brass in the top of the picture.Reading is a little higher than the computer but thats OK, It reads around 200 with a 165 thermastat. The computer stay at around 175.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#7 | |
Re: temp sensor
Re: temp sensor
My suggestion will cost about $20 and is way easier than drilling and tapping a head with the motor in the truck.
Re: temp sensor
grab yourself a 3 wire ls1 temp sensor, two of the outputs go to the ls pcm and the third output goes to your factory temp gauge, very simple no drilling and tapping, replaces the sensor on the drivers side head. You will need the pigtail for it though and its the same as the TPS sensor plug.
I dont think i paid over 20 bucks for mine: http://www.ebay.com/itm/like/380809605775?lpid=82 |
#10 | |
Re: temp sensor
GM part #12551708 for 98 Camaro but I think this one goes in the head?? |
Re: temp sensor
I just bought a scan guage 2 untill i can get my money up
Old member
My temp gauge is from Speed hut for the temperature gauge I got from them so it's not the stock gauge. But there are fittings that will work. I have also seen the 3 wire ls pigtail.
#13 | |
Re: temp sensor
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#14 |
Old member
The 3 wire senor and pig tail is $57.00 at Hawks they have them in stock. I was looking at them while I waited for them to finish up the truck. As stated though I don't know how acrate it would be with the stock truck gauge.
I just ran across this. ![]() ![]() http://www.classicdash.com/shopping/...ation-Kit.html This kit includes the required sensor adapters for the oil pressure gauge and water temperature gauges. As well as a 10K Resistor for the tachometer. The specialized instruction manual, fittings, sensor, and electrical component packaged in this kit make the instrument installation on your GM LS based engine simple and straight forward.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-07-2014 at 08:29 PM. |
#15 | |
Re: temp sensor
#16 | |
Re: temp sensor
#17 |
Re: temp sensor
Hi David, I drilled the face of the water pump and installed the stock sender. ls runs hotter than 1968 standards, gauge read about 3/4th scale. Installed a variable resistor potentiometer in-line and dialed the gauge down to read colder to the 1/2 scale i was looking for. If memory serves me correctly it was a 4 ohm 1/2 watt resistor. I shined up the sender brass terminal for good connections and consistency. Works spot on every time. Pulling the airstream in hot weather it runs about 5/8th scale, equal to about 208 degrees F. Good luck, Brian Fuller
