Old 02-11-2014, 10:25 PM   #1
84ScottsdaleMudding
84 chevy k10 350 motor?
I got this truck in spring and have been restoring it has a 350 v8 with a 4 barrel I think its a LT9. Mainly stock except a edelbrok air cleaner, summit headers, and a high flow dual exhaust I looked up the specs on it and it comes in at a whopping 165 HP HAHA seems a bit low for that kind of engine dosent it? When I step on the gas it barely dose anything is this normal for this engine?What are some good upgrades for this engine that i will see some HP out of I already have a edelbrok intake manifold for it just didn't put it on yet.
84ScottsdaleMudding is offline   Reply With Quote
Old 02-11-2014, 10:42 PM   #2
dman1982
dman1982's Avatar
Re: 84 chevy k10 350 motor?
tire size? tranny? lift? my truck is the same way...i have a lot of miles on it but runs good, mine has 6 inch lift, 35 inch tires...and some bolt ons...a giant slug
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 02-11-2014, 10:50 PM   #3
84ScottsdaleMudding
it has 31s an automatic overdrive tranny and no lift
Old 02-11-2014, 10:57 PM   #4
dman1982
dman1982's Avatar
It sounds pretty stock, these motors didn't have a lot of power stock, I'm about to do a ls swap in mine, if you wanna free up some easy horses with bolt ons, I'd go with a intake (possibly a carb), electric fans, good tune up, I'd also check out those gears...you probably have 3.08's...not good for get up and go
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 02-11-2014, 11:30 PM   #5
68post
A stock low compression engine always needs a better tune (dizzy recurve 'n new quality parts), headers and a great exhaust, a good tuned carb (not stock necessarily) better heads and a better cam for sure. Even tho' you are starting with a low comp engine - it is a 350 that can be made to run without replacing it with a crate. Easily ..
A dizzy recurve first and foremost, then headers (or you'd better change the cam to a custom made can immediately to compensate for a ****ty exhaust).
You may be buying gears too - to help a 4,xxx lb + truck get out of it's own way. That really depends on what you want out of the truck !
It can still look stock and run like stock without a cam lope if that's what you want
68post is offline   Reply With Quote
