Old 02-12-2014, 07:08 PM   #1
69SCSS
69SCSS's Avatar
PS pump swap
Just wanted to make sure since I found one on CL today, will a Power Steering pump for a long water pump still work for a short water pump, as long as I use the short pump brackets? I'm assuming they would bolt on the same, but would the pulley also need to be changed?
I'm running a BBC and since they are hard to come by I wanna jump on an opportunity when i can!
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 02-12-2014, 09:08 PM   #2
hugger6933
Re: PS pump swap
Pumps are the same the brackets are the difference. There is an exception to that and it is a pump from a serpentine setup is a little different in the way that the shaft is a different diameter and the bolt on pulley will not go where the press on pulley was. But the chance that the pump you found is one from a serp set up is small at best. Jim
hugger6933 is offline   Reply With Quote
Old 02-12-2014, 09:15 PM   #3
69SCSS
69SCSS's Avatar
Re: PS pump swap
Well the ad shows a pic of the setup and it's definitely v-belt.
http://portland.craigslist.org/clk/pts/4277457797.html
Looks like a mid-70's truck. Thanks, gonna give the guy a call.
My 68 SWB
Al Silveira Music
Old 02-12-2014, 10:18 PM   #4
franken
Re: PS pump swap
You can get a rebuilt pump from the local parts store for less even if you eat the core charge.
While the pumps are generally the same, the pump is just the inner round iron part, while there are lots of different reservoirs, and some other variations. Buying one from a random big block is a good way to get a pump you can't use.
Some also had remote reservoirs, such as BB SS Chevelles, vans and trucks w/ hydroboost brakes.
franken is offline   Reply With Quote
Old 02-12-2014, 10:28 PM   #5
midniteblues
midniteblues's Avatar
Re: PS pump swap
the swp bbc uses a remote fill ps pump.
even though i havent tried it i dont believe the filler neck on the lwp ps pump will clear the alt on a swp bbc.
although the internals are the same on the two pumps the houseings are differnt.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-12-2014, 10:29 PM   #6
69SCSS
69SCSS's Avatar
Re: PS pump swap
I'm considering switching to long water pump anyway, and he's selling the pump and brackets. I dunno, I have seen the prices at Rock Auto and stuff but they don't come with a pulley, which I'd need also. Kinda fishing right now anyway. Problem is this pump will fit under the alternator and be a PITA to check the fluid or even fill it right. The guy has the alternator brackets too, and pulleys. Going to just check out what he has and if it's reasonable I might go for it as long as it's all complete. Ahh, starting with nothing is fun.
My 68 SWB
Al Silveira Music
Old 02-12-2014, 11:02 PM   #7
69SCSS
69SCSS's Avatar
Re: PS pump swap
So, if I get a pump from Rock Auto or Oreilly's or whoever, should it be a press on pulley or keyway? Looks like a press on: http://www.cardone.com/Products/Prod...d=20140&p=rock
Where would I get the pulley brand new, or would I just have to get one from a yard or off the board used?
My 68 SWB
Al Silveira Music
Old 02-12-2014, 11:08 PM   #8
midniteblues
Re: PS pump swap
when i did my lwp i got a chrome ps pulley off advance auto's shelf that fit perfect it was a key way.
just keep in mind the clearance you'll have between your rad and fan if you swap too a lwp.
with the oe engine mounts in the front holes and a clutch fan mine was too close for comfort thats why i'm swapping too the swp stuff and so far my mock up is goin great..
Old 02-12-2014, 11:31 PM   #9
69SCSS
69SCSS's Avatar
Re: PS pump swap
K looks like this might be the ticket:
http://www.summitracing.com/parts/aaz-20-151/overview/ - keyway pump
http://www.summitracing.com/parts/sum-g3973/overview/ - keyway pulley
At least I think. Not a bad price, like $80 total. If that sounds right then I'll probably skip the local one, rather have new. Would still have to find a reservoir though.
My 68 SWB
Al Silveira Music
