Old 02-16-2014, 09:55 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Door fitment? 91 fit 96?
Will a 91 door fit a 96, as far as inner door panel and everything internally?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-20-2014, 02:30 PM   #2
'71 Chevy
Re: Door fitment? 91 fit 96?
Not sure if this will answer your question. The door shell is the same 88-98. The door panels are not the same. They went to a different style in 1995 IIRC.
You can swap everything over,though. Not to big of a job. Your doors electric or manual?
'71 Chevy is offline   Reply With Quote
Old 02-20-2014, 02:45 PM   #3
1badgmc
1badgmc's Avatar
Correct.
Old 02-20-2014, 03:33 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Electric. Full power. I just hope everything on the inside panel will mount up. Thx.
Old 02-21-2014, 01:37 AM   #5
ray_mcavoy
I'm not sure of the exact years, but I have noticed a small difference among some of the 88 - 98 door shells.
This door is off a 98:
And this one is off a 95. Notice how it has a recessed area near the upper/center of the large opening:
I noticed this a few years ago when I put some 93 doors on a friend's 98 truck. The green door pictured above (without the recessed area) is one of his 98's old doors.
The metal inner panels that screw inside to hold the window regulators & hardware are shaped to match the contour of the door shell in that area. So depending on the parts that are being swapped, there might be an interference issue in that area. Luckily, on my friend's truck, his flat 98 inner metal panels just bridged across that recessed area in the 93 doors.
ray_mcavoy is offline   Reply With Quote
Old 02-21-2014, 06:46 AM   #6
Orangette
The recessed are is for the grab handles on 88-89 trucks.
but as stated, they can still be used.
Josh
1978 RCLB K20, Built 400 SBC, SM465, Lifted
1994 RCSB Silverado, 375HP 350, TH350, 4/6, Toy
Orangette is offline   Reply With Quote
Old 02-22-2014, 12:57 AM   #7
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
This is correct .... I have done it as well , put 93 door on 96 tahoe .... No issues whatsoever. Door panel went right on. You would have an issue going the other way though 96 to 93
ksbrktracer is offline   Reply With Quote
Old 02-22-2014, 11:19 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Thanks for the help guys. I have found a good solid 91 Arizona drivers door for for my 96 Z71. Just want to make sure it will work before I start disassembly of my 96 door.
Old 03-21-2014, 07:51 PM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The steel 96 inner door panel doesn't fit the 91 door like it should. The recessed part for the door handle is moved back slightly on the door. Seems to work ok though. But not an exact fit.
