Old 02-22-2014, 11:21 AM   #1
Malamute
Malamute's Avatar
Aftermarket control arms
I'm hoping to get going on the drop on my '69 soon. Looking at 4.5/6 drop and I'm wondering if I should just clean and rebuild all of the factory components up front or if I should go with an aftermarket upper/lower CA setup.
Like this.....http://www.performanceonline.com/196...KIT-SET-19314/
If not this kit, who else makes a good one?
Thanks.
Malamute is offline   Reply With Quote
Old 02-22-2014, 11:34 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Aftermarket control arms
Been thinking about this myself. Nothing like a lowered long bed that will corner.
A grand for all that in the kit is a good deal.
Subscribed.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-22-2014, 11:38 AM   #3
69chevy lwb
69chevy lwb's Avatar
I have the ride tech setup with 2 inch modular spindles and wilwood d52 calipers. My friends with gti's and Subaru's admit my truck will take there's in the corners the only problem is I have a 6 banger so I cant run that truck to it's full potential
69chevy lwb is offline   Reply With Quote
Old 02-22-2014, 11:58 AM   #4
Malamute
Malamute's Avatar
Looking at the Ridetech and I know it's a CO instead of a spring and shock but it's also $400 steeper in price. I want something that handles better than stock but it's also not going to be a race car.
Keep the thoughts coming, I really want to be certain before I pull the trigger.
Old 02-22-2014, 12:07 PM   #5
69chevy lwb
Mines on air rather than coil overs and still rides great I still need the anti roll bar but I recommend there stuff since they stand behind.it all and it's all proven equipment
Old 02-22-2014, 01:17 PM   #6
70blackfish
I would do springs or air bags, don't really need control arms. spend the money on other stuff, i don't think you can go wrong with porterbuilt stuff. the rear trac bar is the best
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-22-2014, 03:22 PM   #7
big d's red67
big d's red67's Avatar
Best thing about aftermarket control arms is they help with front end alignment when you lower the truck[ ie. the cast and camber]. I have CPP uppers and lowers from POL [a vender on the board] I wish I would have gotten Porterbuilt, Nate's stuff is the best.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 02-22-2014, 03:31 PM   #8
Malamute
Malamute's Avatar
Have PB on my '71 so I concur on their quality. I'll dig into their site.
Old 02-22-2014, 08:52 PM   #9
YBNORML
YBNORML's Avatar
What don't you like about the CPP arms? I have been thinking of buying these myself. I love Nates stuff but I don't have the time to wait for them.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-22-2014, 08:56 PM   #10
big d's red67
I didn't mean to give the impression I don't like the CPP arms, there great I have the PB rear trailing arms and just wished they all matched and I would have liked to have narrowed my track width.
Old 02-22-2014, 08:58 PM   #11
YBNORML
YBNORML's Avatar
Gotcha, thanks.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-24-2014, 01:28 AM   #12
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
If it were me and I was going to do a suspension for handling without doing a complete drop member I would go this route; PB tubular forward arms for the front to center the wheel in the opening and correct the geometry along with the larger Anti-roll bar that goes with them. For the rear I'd use a stage 2 rear kit but set up for coil springs and an anti-roll bar. The real trick will be a complete set of Ride Tech single adjustable HQ series shocks. Up front the shock would go in the stock location, but in the rear they would be mounted more vertically on the PB shock crossmembers allowing them to work better. I'd also figure a way to include a rear anti-roll bar. I think this set up, while not as "cool" as the full PB drop member treatment, will handle really well and reduce the cost versus a full dropmember by maybe 50%. Just my 2¢
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-24-2014, 01:45 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Another vote for Porterbuilt.
Get their Forward Series a-arms like Buck said.
Nate will add a bolt in coil spring mount for the lower a-arm that can be removed at a later date if you ever want to switch to bags or coil overs.
Top of the line stuff.
The only other affordable a-arm would be CPP arms purchased through a reliable vendor.
But your wheels will still be in the stock location.
Rearward in the fender opening.
Go Porterbuilt.
Keith
Convert to disc brakes.
Old 02-24-2014, 02:01 AM   #14
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
I agree with using porterbuilt great parts.. The cpp arms I have used and had good luck with them but never have liked how the upper ball joints bolt on and have a shear point and don't sit in the arm and bolt down..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-24-2014, 10:51 AM   #15
Malamute
Malamute's Avatar
Thanks guys, I think PB will be the plan.
Old 02-24-2014, 12:15 PM   #16
Oly72C20
Subscribed...
I just wish there were options for lowering 3/4 tons...
Joe
Oly72C20 is offline   Reply With Quote
Old 02-24-2014, 12:18 PM   #17
lolife99
lolife99's Avatar
Originally Posted by Oly72C20 View Post
Subscribed...
Joe
Porterbuilt makes 3/4 ton a-arms and several companies make 3/4-ton drop spindles.
Keith
Old 02-24-2014, 12:22 PM   #18
Oly72C20
Thank you Keith. I will look at Porter Build for A arms, I must not be checking the right spots for drop spindles.
Joe
Old 02-24-2014, 12:44 PM   #19
C10_ustacould
Sweet!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-24-2014, 12:52 PM   #20
lolife99
lolife99's Avatar
Joe
Keith
Old 02-24-2014, 01:01 PM   #21
Oly72C20
Sweet! Thank you!
Old 02-24-2014, 01:45 PM   #22
70blackfish
AZperformance is a really good PB source
