Old 02-23-2014, 01:27 PM   #1
ChrisWhewell
ChrisWhewell's Avatar
Front fender emblem
Got an emblem for the front fender of my 67 3/4 ton, but.... how the heck can I install it without pulling body panels off ? arrgh!!
'67 K-20 longbed 4X4,
350, SM-420, Vortec heads,
flat top 4-brow pistons,
Eaton 4.55's, Qjet,
MSD 8365, Comp XE250H,
Dynomax duals
ChrisWhewell is offline   Reply With Quote
Old 02-23-2014, 01:41 PM   #2
bigmac73
bigmac73's Avatar
Re: Front fender emblem
i think you might have to drop the inner fender and reach up from the bottom
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-23-2014, 03:01 PM   #3
Lou Boffa
Lou Boffa's Avatar
that's what I did. Dropped the inners, loosened (not removed) the fenders then used a ratchet wrench w some tape to hold the speed nut while I positioned and tightened. Takes some wiggling but it did work for both emblems on each side.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 02-23-2014, 03:16 PM   #4
Agent915
Badging on some vehicles were held on by "barrel" clips. (If you see one you'll know why its called that.) They're simply slid down over the prong, where you would place the speed nut, then you just push the badge into place. You'll hear the tabs "pop" when they lock it into position. Probably find them at any parts store or dealership. They're easy on/easy off!
Danny
Agent915 is offline   Reply With Quote
Old 02-23-2014, 08:14 PM   #5
Z10
Z10's Avatar
Yep, drop the inner fender. Really not a big deal. You can see a few pics on my build thread where I replaced the fender emblems.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-23-2014, 09:36 PM   #6
bigmac73
bigmac73's Avatar
how come my fenders dont have holes for the emblems, is this common with OEM replacements or aftermarket
Mike
Old 02-23-2014, 09:58 PM   #7
Z10
Z10's Avatar
Probably so. To many different types of emblems and bolt hole paterns to stock for specific applications. Check out my build thread and you'll see where I made emplates to mount them.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
