Old 02-24-2014, 03:35 PM   #1
lutronjim
Dakota Digital ECD-100
Wondering if anyone has any experience using this unit to drive mechanical speedo .
Planning LC9 and L465E swap into my 70 Chev C10 pickup and want to keep original speedo. The VSS from the tranny will be needed for PCM. I have read from post that splitting VSS signal to PCM caused shifting problems.
Don't know if VSS output from PCM would work or not. GM says its 'not scaled' whatever that means.
I also looked at Cable-X unit but read of several problems.
lutronjim is offline   Reply With Quote
Old 02-24-2014, 07:40 PM   #2
truckdude239
truckdude239's Avatar
Re: Dakota Digital ECD-100
I have a wire commi g off my pcm labeled speedo speedo will pull from the computer
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
