Old 02-27-2014, 11:25 PM   #1
cochino12
It followed me home?
cochino12's Avatar
removing pw pl harness
If I unplug the actuator and window motor will the harness/plugs pull through the door jamb? If not how do I get the harness out without cutting the harness?
thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-27-2014, 11:52 PM   #2
gmachinz
Re: removing pw pl harness
They are a pita to pull through the accessory boot inside the door jamb. There are several retainging clips that secure the harness away from the window frame inside the door shell and along the outside as well. About a foot above the kick panel is where the main connectors are at to unplug the harness but they are pretty bulky pulling through the accessory boot....with a little patience it can be done.
gmachinz is offline   Reply With Quote
Old 02-28-2014, 01:07 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
mark the location,take the wires out of the plug
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-28-2014, 09:22 AM   #4
bigd65
bigd65's Avatar
I pulled mine, but I pulled the boots and all... Gonna find rubber plugs to put in the holes. You just have to go slow with it.... It is a PITA though
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 02-28-2014, 10:01 AM   #5
Greenlee
Greenlee's Avatar
I did this without cutting any wires or taking apart the plug. I pulled the other end through the door jam (the square plug under the dash). To get it back through to reinstall it I taped a rope to it with electrical tape and pulled it through.
Greenlee is offline   Reply With Quote
Old 02-28-2014, 10:22 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Just to mention not all trucks are wired the same, you may have to move some wires anyway,if reusing/swapping trucks,
John
