Old 07-23-2003, 06:10 PM   #1
Merl4
Wheelbase
Today I looked at a frame for a 1968 C-10 and the wheelbase measured approximately 133". I believe I read somewhere the shortbox was 115" and the longbed is 133". Can someone direct me to the right answer.
Thank you
Merl4 is offline   Reply With Quote
Old 07-24-2003, 08:53 AM   #2
crazy longhorn
Fabricate till you "puke"
Shortbed was 115", longbed 127", & the Longhorn was a 133" wheelbase. The longhorn was an 8 1/2' box,& available in 20 & 30 series only, & will have leaf springs on the rear. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-24-2003, 08:57 AM   #3
Merl4
Whelbase
Thank you for the reply.......This frame is 133 and has the springs near the rear.
Old 08-02-2003, 05:53 PM   #4
Merl4
133" Wheelbase
I still have questions about this long wheel base frame. I bought it to shorten it to the 115" wheelbase to fit my shortbed.
I can't find much info on this wheelbase configuration, only that it may have been a "Longhorn".
I would feel silly to cut this frame down to the 115" and find out that it is a somewhat rare frame and should be preserved.
Any suggestions or history is appreciated.
Thank you,
Merl
Old 08-02-2003, 07:38 PM   #5
krue
Designated A-hole!
krue's Avatar
Post this on the 67-72 Message Board and you will get more response. I am sure that our resident Longhorn "fanatic and guru" Longhornmail can tell you what you need to know about it!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-02-2003, 08:59 PM   #6
crazy longhorn
The longhorn used the same chassis that would be found under a 30 series (133 wb) dump truck. The dump truck had dual wheels, & an extra stack of leafs.....otherwise, the spring lenght,& width spacing should be the same. crazyL
