Old 03-05-2014, 09:16 PM   #1
mafosa
bulkhead connector
anyone know how to get this whole connector out? wires are all cut on the inside.
im rewiring the whole truck. 20 circuit kit. I tried everything to unlock it.
thanks!
larry
mafosa is offline   Reply With Quote
Old 03-05-2014, 11:19 PM   #2
pimpston65
pimpston65's Avatar
Re: bulkhead connector
when i took mine out i started at one edge and puckered it as i was pushing it through the hole. i came out throught the compartment side
pimpston65 is offline   Reply With Quote
Old 03-05-2014, 11:19 PM   #3
pimpston65
pimpston65's Avatar
thanks!
larry
if all else fails cut the gasket
Old 03-06-2014, 12:24 AM   #4
argonaut
argonaut's Avatar
Use a heat gun. The rubber gets hard as a rock over 50 years but a little heat can make it pliable again. Once heated and pliable you want to push it through into the engine compartment. Then you can remove the grommet and pull the connector back out.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-06-2014, 09:53 AM   #5
mafosa
Angry Re: bulkhead connector
http://store.alternatorparts.com/140...lternator.aspx
this dude has all the parts if something goes wrong. he has a channel on youtube.
"alternatorman" is his channel I think?
now the the "off topic". when I was rewiring my starter I discovered a 5" crack along the bottom of the spark plugs.
kinda threw a wet blanket on my project.
Old 03-06-2014, 09:57 PM   #6
mafosa
ok fellas.. the heat gun did the trick. thanks!!
look like I posted in my own wrong tread.
larry
Old 03-06-2014, 10:36 PM   #7
Rich 5150 69
Rich 5150 69's Avatar
Block is toast...you been running this way....?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-07-2014, 10:33 AM   #8
mafosa
just bought the truck about 6 months ago. been slowly restoring it. mostly safety things.
I was going to put a carbed 5.3 motor. next year. looks like im moving that project to the front burner.
ill nurse this motor along till it gernades on me.
larry
Old 03-07-2014, 10:34 AM   #9
mafosa
so, yes.. not every day though.
Old 03-07-2014, 04:12 PM   #10
blazer-k5
blazer-k5's Avatar
Pull it...vat it....dip it in chrome...make a table out of it.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 03-07-2014, 04:28 PM   #11
mafosa
already have a nice out door plant stand. lol! via 5.7 hemi block.
larry
