battery relocation
after removing the inner fenders, where is anyone one mounting the battery? since the original tray bolted on to the inner fender? thanks in advance
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
Re: battery relocation
I mounted mine under the front pass seat off the frame rail (C30 CC dually w/SloshTubz)....
do you have any other pics?
Not currently. I made the frame-work for the box from some 1.5" angle. I cut-up an OE battery tray & welded it to the bottom of the frame work. The sides of the batt-box frame are drilled & matching/drilled pieces of angle are bolted to the trucks frame. This allows me to drop the entire batt-box down for service.
I would have used the readily available 'drop-down' style of box but it didn't look like I'd be able to get it high enough on the frame rail to keep it out of sight from the rocker. So... spend the $$ & it possibly not work or DIY. Making my own ensured it was hidden as much as possible while still allowing clearance for cable installs. I also used a dual terminal battery (top posts for the starting circuit; side posts for accessory circuits & jump starting). With everything cleaned up & painted chassis black + the truck being lowered now, you cant tell it's there unless you poke your head under the rocker. I tried taking more pics when I took that one but it was too dark for good quality shots.
gotcha, thanks Scotti
drop down box, behind the right rear wheel.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Check out Korbin's build, he placed his battery on the frame where the passenger tank would go. There are pictures on this link, in Post #472. Note he has a Blazer/Suburban gas tank in lieu of the passenger tanks.
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper.
thank you
At the body shop.
![]() The shut off is below the floor now.
" That didnt make it any newer " " Dont antique the equipment " |
Glen
I moved mine to the back with a modified tray from Speedway Motors.
Glen Simpson Severed Ties - Oregon Roseburg, Oregon
Past Trucks
Glen
Another shot
Past Trucks
| Bookmarks |
