Old 03-18-2014, 01:41 AM   #1
dondons84
1975 k10
Hey guys so I'm stuck hard. I am replacing my front ball joint (upper) and I can't get it out at all. I have used a pickle fork and banged on it good and nothing. So I guess I have to take off some parts or something to get it to cone loose? Heat? What do I do?
dondons84 is offline   Reply With Quote
Old 03-18-2014, 08:49 AM   #2
05duramaxhd
Re: 1975 k10
autozone rents a ball joint tool looks like a big C-clamp. they are pressed in
05duramaxhd is offline   Reply With Quote
Old 03-18-2014, 12:17 PM   #3
willett
Another Day, Another Dollar
willett's Avatar
Re: 1975 k10
Hammer on the side of the casting that the joint presses into while prying lightly on the bj
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-18-2014, 12:29 PM   #4
dondons84
Re: 1975 k10
My problem I am having is the but that I removed was from the top and not under. I think the idiot put them on backwards cause everything I see has the bolt under and not on top
Old 03-18-2014, 12:43 PM   #5
crashz
crashz's Avatar
Re: 1975 k10
The ball joints sit in the outer section of the knuckle and the tapered end are bolted into the inner section on the axle housing. I really can't remember the way I've done these (its been ~20 years), but I do remember this:
When installing the new taper ball joint stud, DO NOT over-tighten. I tightened up the castle nut to as tight as I could move the wrench (I was young and had no idea about fastener torque, thought everything was tighten to gorilla strength). I needed just a little more to insert the cotter pin. Used a cheater to get the extra 1/8th turn, reassembled and put the truck on the ground (this was my 83 K2500). As soon as the weight was on the front I heard a loud bang like a gunshot. Sure enough, I cracked the housing at the outer most point along the tapered seat. Had to junk the front axle that I finished rebuilding.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
