Old 03-20-2014, 08:50 PM   #1
NASTY-LSX
Ok, what did I almost tear up driving 65/70 in 4 wheel drive
I drove into my friends yard and almost sunk. So I did not want to tear up his yard so i put it in 4x4. 4 high. after i parked, I forgot i had it in 4 high, but i did put my hubs in free mode after i got off his yard. long story short,
I drove 45 miles about 65/70 with my hubs in freemode and my shifter in 4 high.
In normal driving conditions you cannot tell its in 4 wheel drive mode. On the freeway i did feel a slight vibration. When i got home I had what looked to be ATF fluid on my tailgate and all over the bottom of the truck, not severe but just coated.
truck is back in 2 wheel mode and runs just fine, But if Im correct, your never suppose to drive in 4x4 mode on concrete. So can i ruin anything, or if something was gonna break i guess it would have already broke huh?.
I have taken my truck to the car was and wash underneath, no oil leaking now, but i need to make sure there is oil in the TC. What type of oil do i put in the 208 TC?? Thanks
NASTY-LSX is offline   Reply With Quote
Old 03-21-2014, 04:14 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Ok, what did I almost tear up driving 65/70 in 4 wheel drive
Your t-case will hold about 3 quarts dexron VI auto trans fluid.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-21-2014, 09:29 AM   #3
79Betty
79Betty's Avatar
Put some fluid iner and if it still doesn't leak i'd say u had too much pressure in it causing overflow
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 03-21-2014, 09:52 AM   #4
NASTY-LSX
so how do i tell when there is enough fluid. Do I just top it off to the fill hole??
Old 03-21-2014, 10:00 AM   #5
Mattchu60
I wouldn't think it could hurt much at all if you didn't have the hubs locked. Wouldn't matter if you were driving on concrete/asphalt/dirt because the driveline dose not care what/where you are driving if the hubs are unlocked (they are not connected to the ground since your hubs are free-wheeling).
I don't know why you would have fluid everywhere though, that seems odd. maybe it was overfull? I would check the T-case fluid level and if its near full, leave it alone.
Personally I live in IA and somedays when we have snowstorms I will put the truck in 4x4 and drive 55-60mph for 15-20 miles, I've never had an issue with it.
Mattchu60 is offline   Reply With Quote
Old 03-21-2014, 11:03 AM   #6
walkerb
walkerb's Avatar
yes, that what I always did with no issues.
Depending when you changed it last, now would be an excellent time to drain
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-21-2014, 12:45 PM   #7
NASTY-LSX
Yea, your right.. its only three quarts
Old 03-21-2014, 03:00 PM   #8
83GMCK2500
While you're under there check the vent line, I would pull it off completely and run some compressed air through it, make sure there is no plugs/obstructions, also checking the plastic vent cap in the process. If the tcase heated up and that vent line was obstructed it could've caused the oil to push out the rear output.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-22-2014, 01:03 AM   #9
kalbert
You could also have a bad seal between the transmission and transfer case allowing ATF to leak from the transmission to the transfer case causing it to be over full. Check your levels, you'll know right away where the oil came from. Something will be low and/or something will be over full.
kalbert is offline   Reply With Quote
Old 03-24-2014, 12:27 AM   #10
cedens
cedens's Avatar
How did you not see a blaring orange light on the speedo that reads "4 Wheel Drive"
1982 K10 Scottsdale
2006 1500 Sierra
2010 2500 HD Z71 Silverado
cedens is offline   Reply With Quote
Old 03-24-2014, 01:03 AM   #11
willett
Another Day, Another Dollar
willett's Avatar
Maybe he doesn't have one ...??
Mine doesn't work...
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
