Old 03-21-2014, 09:49 PM   #1
Houses
Rear Sway Bar
Does anyone have pictures of their rear sway bar set up? I have a sway bar from a Camaro cuz I had read that other had done that. what I didn't notice was that they were all trail arm set ups. I sorta played around trying to mock it up but kept hitting the shocks. I know you clamp onto the rear end and the links to the frame with spacers. anyways any help is appreciated.
Houses is offline   Reply With Quote
Old 03-22-2014, 12:50 AM   #2
Aaron_L
Re: Rear Sway Bar
The Camaro one is too wide, it hits the shock mounts. I have one too, lol. I thought about cutting the shock mounts off and running a leaf spring plate with a shock mount on it, like on a car. Then building a crossmember for upper shock mounts. But it seems like a lot of work just to use this bar.
Aaron_L is offline   Reply With Quote
Old 03-22-2014, 04:28 PM   #3
bdiamond
Re: Rear Sway Bar
Would it mount pointing backwards? Or would it hit the other shock mount then? You might try a 92-00 suburban bar. Its 7/8" bar. In stock form it mounts under the frame. I can take some measurements if you need.
bdiamond is offline   Reply With Quote
Old 03-22-2014, 04:55 PM   #4
Aaron_L
Re: Rear Sway Bar
You could probably get away with mounting it on top of the axle. I plan on flipping the axle, and I want to run full exhaust, so I don't think it would be an option for me.
Old 03-22-2014, 05:25 PM   #5
Houses
Re: Rear Sway Bar
yeah that's what I thought. mounting it backwards just makes it hit the other shock. I should have done some better research before getting ahead of myself ha ha ha
bdiamond: do you have one installed or you own a suburban? sure measurements would be good if you have some the time. thank you.
Old 03-22-2014, 08:11 PM   #6
bdiamond
Re: Rear Sway Bar
I have a Blazer I had planned putting one on. Ended up getting a smoking deal on a pair of Belltech bars and installed them instead. I'll get measurements for you in a bit.
Old 03-22-2014, 08:26 PM   #7
bdiamond
Re: Rear Sway Bar
Center to center of axle bushings= 30.5"
Center to center of frame mounts= 37"
From the axle mount to the endlink mount =12"
It is shaped just like this one http://www.ebay.com/itm/Belltech-94-...-/291026355912
the only difference is the endlinks are rotated 90* from this
