Auto To Manual Trans What Do I Need??
Ok I got a 1986 gmc Sierra k2500 350 700r4 trans np208 transfercase 8ft box 4x4.
I would like to switch it over to a manual 5speed with hydrolic slave cylinder. I'm just not sure I what truck I should look for for this swap? And what transmission/t-case and crossmember I would need? |
Re: Auto To Manual Trans What Do I Need??
For a 5 speed. Your two main options are the nv3500 from an S-10 or 1/2 ton. Or the nv4500 from a 3/4 or 1 ton. Both from the 90's
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's |
I'd rather go nv4500 or if I have to go 4speed I will.
Moderator
![]() Join Date: Oct 2008
1985-91 CK RV have hydraulic clutch pedals.
The 85-91 CK RV cabs have dimples on the firewall for the Clutch master cylinder. Prior to that you'll need to improvise. You can adapt or buy a mechanical clutch bellhousing for the NV4500 but it's not as easy as adapting the cab to a hydraulic clutch pedal setup.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I swapped from a th400 to the sm465. I like it. As long as I don't have to drive in busy traffic.
| Bookmarks |
